2017-2019 Super Duty FORScan Spreadsheet
#3003
Tried delay in headlights original 726 26 01 0100 0000 0055 was suppose to put a 0 for 15 sec delay...already has 0...and lights turn on right away in dark, any help?
also power point 4 hr timeout does not change. 726 39 01 1194 original...changed to 726 39 01 3870...nothing...power ac adapter still needs truck running to be on....any help? Thx
#3005
Thanks...I do think I was messing up secure idle. I will go back and revisit that. However I did enter the horn honk right and when leaving the truck with the keyfob it still honks. I noticed 2 different horn honks listed. Also see 726-38-02. Are they different? Sorry just cutting my teeth on this. Thanks
Thanks.
#3006
#3007
ZooDad
#3010
#3012
#3013
Truck has to be to running for ac adapter...my bad.
#3014
#3015
I made the last few changes I wanted using FORScan today. Enabled digital temperature read-outs above gauges, reduced the turn signal flash-count from 3 to 1, and disabled the door chime when a door is opened while ignition is on. I did change the infotainment screen to the "GT" version, but it was not appealing to me so I changed it back to as-built.
