2017-2019 Super Duty FORScan Spreadsheet
#2206
Any idea why I'm getting these strange results??
I changed the TPMS settings and my rear tpms isn't reading properly.
Initially I had the pressure set to 55 / 50 (f/r) and it shows only single digit for the rear.
I've since set the pressure numbers the same (55psi) front / rear but the results seem to be the same.
#2207
on
Those changes have proven to work. You may find that a couple of the updates are already done on your truck and will not required change. Don't worry that the first column is different than your truck. It is only for a very specific configuration and likely won't match your truck.
#2208
I used my navigation today in my Taurus for the first time since I changed to be able to edit while driving. Notice it did not tell me which way to go at upcoming turns. Instead of saying “in 1/4 mike turn left on blah blah” it would just announce the street name and that’s all. Has anyone else noticed this?
#2209
do I have to check and (possibly) change every one of those BCM, DDM & PDM rows ?
#2210
#2211
I didn't change the IPC line because I didn't care whether the "roll-up" option showed up in the menu. It works perfectly, I just can't disable it from the menu.
#2212
On Global Open/Close - is it necessary to change ALL of these module settings?
Also my configuration doesn't match the spreadsheet entry pictured above - IPC, 720-02-01 -
My configuration looks like this -
My truck showed the same configuration as yours (6 instead of 3). It worked. Making all the changes is nescessary as stated above, the IPC change adds the option in the menu to check/uncheck global close, the others enable global close to work so the body control module can send out the signal to close the windows and drivers door module, and passenger door module will accept the command and respond accordingly.
#2213
Ok. I haven’t hardly driven the truck since I made the changes to the nav in forscan, will drive it tonight to see what it does. In my Taurus I don’t mind as much because I can see the nav details in the on my dashboard screen so I don’t have to look at the sync screen all the time to see which way to turn, would be nice to be able to have that on the truck.
#2215
There are instructions in my tutorial linked in my signature below
#2216
#2217
726-40-02 0100 0201 0174
726-40-02 x*xx xxxx xxxx TPMS Sensor AutoRange Cfg: 0=off, 1=on
#2218
My first time using Forscan. Registered on the forum and generated the extended license. Tried backing up modules and this keeps popping up. What am I doing wrong? Im using a MAC and running Parallels. Just wanted to throw that out there. Not sure if it affects anything. Thanks in advance.
#2219
#2220
Copy the Hardware ID (found in FORScan software under the steering wheel with a question mark icon). Download FORScan
3. Generate the Extended License (free) using the previously copied Hardware ID.
