Truck not cranking or starting!
The title of your thread says "not cranking or starting" but your post says nothing about either, just that it died while running. Given that it died it would stand to reason that it wouldn't start either, and could be anything (although the tach dropping to zero indicates that it's affecting the ignition).
But "won't crank" generally means that it doesn't turn over when you engage the starter. That would tend to mean the starter isn't getting power which wouldn't cause it to die unless the entire truck completely lost electrical power.
So if you meant what you said in the title, then I'd look for a broken battery cable, a REALLY corroded connection or a completely dead battery.
FWIW, I had that happen on my '02 diesel. The alternator had died and eventually the batteries ran down to where the PCM wasn't happy and the engine died. When I tried to restart it obviously it wouldn't turn over (crank) with the batteries that dead.
Unless gassers are very different, the PCM has no control over the starting (cranking) circuit. So if it stalled, and it won't crank, and there's a single underlying cause of the two, then it would fall into one of three general possibilities:
* Main power / ground / fusible link issue (see above). This would affect both starting and running circuits. Lots of places to check there; the ignition switch can't be ruled out
* Extremely discharged battery and inop charging system (see end of post #5)
* Seized engine crankshaft - try to turn the engine by hand.
RangerHaywood
09-06-2010 09:55 PM
fepowerguy8
56
07-07-2010 07:13 PM
