2004 Explorer with engine noise
Old Nov 3, 2016 | 02:39 AM
Michel Bertrand's Avatar
Michel Bertrand
Hi guys and gals, I've got a 2004 Explorer XLT with a 4.0 liter engine. It just started clacking this past Sunday. Sound from the top front driver side. Does anyone have advice as to what it may be. Could it be a valve, lifter or some suggest timing chain plastic tensioner.
Thanks,
Mike
Old Nov 3, 2016 | 06:56 AM
shorod's Avatar
shorod
Are you familiar with what an exhaust tick sounds like? Could it be an exhaust leak from a broken exhaust manifold or manifold stud?
Do you know if your 4.0 L is the SOHC or OHV variant?
Other than the noise, does the engine seem to run fine?
-Rod
Old Nov 3, 2016 | 11:21 AM
70f100longbed's Avatar
70f100longbed
Most likely you have a broken chain guide. Its a SOHC the OHV was discontinued in 2001.
Nand12
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 17, 2015 09:31 PM
fstann
1983 - 2012 Ranger & B-Series
Feb 23, 2012 12:49 PM
rynocon
Jul 13, 2010 07:40 AM
estwing17
Jun 21, 2008 12:14 AM
