superspring or air bag to cure the "squats"
#31
#32
You guys are over thinking this. The OP has 950lbs of tongue weight on a 6500lb trailer. He should be shifting weight inside the trailer, never mind worrying about adjusting a WDH. You shouldn't even need a WDH for a 6500lb trailer.
As far as fixing squat; I installed a set of RideRite airbags on my truck. I've probably got an inch of squat with the 2000lbs that live in the bed at 80 psi; just a little taller than level with the front.
@meborder From my personal experience. A saggy rear and a front that remains the same height loaded causes porposing. Also, the sway control is not as effective from lack of friction. At least on an Equalizer type wdh hitch that relies on friction.
I will say I completely agree with you on the air bags and wdh usage. To me it adds another level of complexity for weight transfer and sway control.
To me, its usefulness would be to air them up high in the rear, add the bars and drop to level adding friction and weight transfer. As you said. Airing to level then adding the bars would make it high in the rear when you adjust for tension.
todouble
Fifth Wheel & Gooseneck RV Towing
11-28-2013 05:01 PM
Duanne
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
04-19-2005 08:16 PM
dtpatt2
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-24-2003 01:30 PM
