Mad Max Truck: updates and issues as we go along
update:
carb has been rebuilt, drained the oil out of the pan. was more like 50/50 gas-oil from the many times of trying to turn her over before discovering she rode the short bus (retarded timing) discover one of the factory freeze plug has gone wrong. discussed plan of attack with the old blackthumb (my Dad) decide to kill two rocks with one bird by pulling the engine. then we can give her a proper cleaning and easily do the plugs. the list has snowballed but such it is with an old vehicle and thankfully the parts are relatively inexpensive and easy to come by.
stay tuned for the next episode
I'm a woman actually, no harm though. not sure what you mean by silicone entry, might not be remembering an earlier entry right.
the agenda this weekend is to clear a space in the garage to set the engine down onto. will probably grab a pallet to rest it on. so many projects! if we're exceptionally lucky we might be able to squeeze this out by September but that's being really optimistic.
but with the engine out I can get into the bay and scrape all that finely layered melange of power steering fluid, brake fluid and oil off
current list
freeze plugs, oil pan gasket & zinc oil, belts n hoses, trans gasket & fluid, electric fan & alternator conversion, radius arm bushings, steering box, brake booster & headers.
then donuts. donuts are an essential part of any car build
current list
Still alive. My Daily threw a timing belt so any progress we were going to start on the truck got pushed back. once we get the grocery getter buttoned up we're eager to get greasy. we have a possible lead on a Dually axle that I think would be great fun to have under there. I know it wasn't a factory option but certainly falls into the Rule of Cool
well the dually axle was left under a roof leak so is junk so that won't be happening.
the truck has a Dana 60 under it as it came but my husband, through much opinions and suggestions of coworkers, wants to swap it for a 9-inch. I know the ease of workability is what the 9 is known for but not sure what the swap will do for us, such as MPG or Hwy speeds.
If you swap the rear to a 9 inch you will have to swap out the front for the lighter 5 bolt front end. Since you already have front disc brakes I would keep the Dana 60 rear. You will only need one set of wheels that way. If you are concerned about highway driving you could swap the tranny for a more modern 5 speed with overdrive.
#29
very true. and no way to be completely sure until you open it up to see. I'll talk with him about dropping it out and taking it to someone who can do all the difficult things (or willing to teach). especially as he has his heart set on going dually down the road I don't see a good reason to go through another axle halfway. of course i'm just brain vomiting right now.
