RV belly fabric repair
Old 10-29-2016, 02:20 PM
scraprat's Avatar
scraprat
scraprat is offline
scraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant futurescraprat has a brilliant future
Finally got around to repairing the belly fabric where the propane lines enter from underneath. Cleaned real good with alcohol and applied the fabric tape. I tried using gorilla tape and didn't hold up to the road moisture.
Might want to peak under the trailer for entry points for the unwanted guest.
Old 10-29-2016, 02:22 PM
Sous's Avatar
Sous
Sous is online now
Sous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputationSous has a superb reputation
Is this what you used?
https://www.amazon.com/dp/B002SSGAZG...I36HRF0YMZC5EF
It looks like you did a good job and took your time.
Old 10-29-2016, 02:39 PM
scraprat's Avatar
scraprat
scraprat is offline
That's it and worked great. The hardest part was trying to get the backing off of the fabric with fat fingers. Tried to get some of it smoother but the wind is huffing pretty good and tomorrow is relocation day to next the spot so today is maintenance while I have a chance.
Old 10-29-2016, 03:52 PM
Good listener
Good listener is offline
Good listener is gaining momentum as a positive member of FTE.Good listener is gaining momentum as a positive member of FTE.
Nice work! Belly tape is amazingly sticky and tough. It's really hard to get off the backing when your fingers are cold!
Muppy1840
11-27-2017 07:46 PM
mudguts
09-26-2017 09:40 AM
coolidge54
2017+ Super Duty
11-13-2016 01:03 PM
hitekhomeless
1999 to 2016 Super Duty
17
08-31-2016 04:19 PM
Armytruckchuck
08-25-2016 10:42 AM
Quick Reply: RV belly fabric repair
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
