Tim's Bronco Build
#151
Received 3,530 Likes
on
I bought some used 35 spline axles from a friend and a Yukon Zip Locker and then of course I needed a heavy duty third member carrier! Sense I am having back problems I decided to build an adapter for my floor jack to handle the Third Member.
After I install the air line I used some good RTV to harden the lines ( glue them to the housing ) I thought I had a photo of that but after looking I guess not!
#152
#153
on
#155
on
#156
#157
#158
The following users liked this post:
#159
on
#160
#161
#162
on
Here are a few more photos. Fabbing up the 4-Link.
I started out just clamping the brackets in place.
I didn't like how the lower front bracket was working out and I wanted it a little closer to the front mount. So, I cut it down a little. I like it much better. I will cut the angle iron down before I do the final welds.
I picked up a sway bar from Duff and thought I would mount it to the rear. It's not going to work back there as the fuel tank sets there.
It looks like this is what I will end up with. I will have to trim the ends of sway bar arms just a little as I moved the body mounts back a few inches to accommodate the lowered the floor.
Fabbing up the link bars with PVC to make sure everything is right before cutting the DOM tubing.
#163
#164
Received 5,149 Likes
on
#165
