The revival of "Big Red"
Today began a new chapter in the life of this ol' truck, as she was formally introduced to her new homeland Sweden. This morning at 7 my friend Dennis and I left for Gothenburg, a three hour drive in the rain
We got to borrow a converted Saab 9000, a "Solstad Saab", capable if loading 2 tons.
The rain cleared, and by the time we arrived the sun was shining, and there she was!
Two flat tires, left front wheel locked up, and looking as lovely as ever! Another car had made it over too
All was going well, and then BAAMM! The hood latch decided it had done it's bit, and let go... the hood popped straight up like a sail, bent the hinges and bounched up against the cab...on the freeway...at 70mph...
All in all, it could have been worse... now atleast She's in the garage, ready for the next step...
Also, that image of it loaded on the converted Saab is one of the stranger automotive things I've seen.
The following users liked this post:
My plan is to first get it back on the road, and then have it as a rolling project, gradually improving it as I go... I like the patina, and I have a really good body-guy, who can keep the look even if we have to fix some holes along the way.
Congratulations on the aquisition of the truck. It's probably not too common to see one of these old trucks in Sweden.
I had recently worked on a friend's '72 F100 (I put front discs and a power brake booster on it). Notice the ratchet strap going across the hood. He didn't want to risk the hood flying up on its 87 mile trip back home.
While it's something you hate to have happen, it can be fixed.
This is a photo from last weekend when I drove up to where my friend lives. We went to the wrecking yard to get some parts off of some Bumpside ('67-'72), Dentside ('73-'79) and Bullnose ('80-'86) Ford trucks. My truck is the dark green '69 F100 short bed Ranger.
Got two of my sons to come with me to the garage to push and pull the ol' girl into her bay, and while we were at it I thought I'd try and loosen the seized up left front wheel... any tricks to getting the drum off? I got this far;
The cap, pin and center nut came right off, no problem at all. The bottom half of the drum can be pulled out about half an inch, but then it goes right back, as if it is hooked on a spring...
Oh well, I'll read the shop manual I bought and see what it says too. Big Red will just have to wait until I return... she's pretty though
Most likely the drum brake shoes are seized to the inner surface of the drum. Back the adjuster all the way off and take a hammer and bang on the outside, perimeter of the drum --but, don't get too carried away doing this. It can shatter the drum casting if you hit it too hard.
You may also have to apply some heat from a torch to the circumference of the drum to get it to expand away from the brake shoes.
