Sponsored by: Real Truck
Engine noise
Old Oct 27, 2016 | 01:17 PM
flyingtexan's Avatar
flyingtexan
Engine noise
My 2002 F250 with the 5.4 (215,000 miles) has a loud tap upon start up, only on the passenger side, heard best in the wheel well. It only lasts about 30 seconds to a minute. Any ideas? It occasionally rears it's head driving around town but only intermittently. Just drove it 275 miles, at 13mpg, truck runs fine, just annoying.
Thanks in advance.
Old Oct 27, 2016 | 03:08 PM
Boaterguy's Avatar
Boaterguy
High mileage could always be a lifter noise. The 5.4 also had cam phasers. They are driven by oil pressure and when they wear out don't keep the correct tension on the timing chain. Mostly noticed at start up after sitting a while, motor will sound design like a sewing machine until oil pressure is built up. A single tick on one side can also be traced to an exhaust leak at the manifold.
Old Oct 27, 2016 | 04:36 PM
BigBlockF350's Avatar
BigBlockF350
Like the last guy said, it could be a lifter. I would check and see if any of your exhaust manifold bolts are broken though, a very common issue on those engines.
Old Oct 27, 2016 | 04:40 PM
Mike189677's Avatar
Mike189677
Op's 5.4 is an 02 so no cam phasers those didn't show up till 05
Old Oct 27, 2016 | 04:44 PM
Boaterguy's Avatar
Boaterguy
I was taking a guess, I never owned one. See, you learn something new every day!
Old Oct 27, 2016 | 07:01 PM
Kdr358's Avatar
Kdr358
+1 on those pesky exhaust manifold studs... they snap off over time creating a small gap.
Once the engine warms up the metal expands and temporarily closes the gap
Old Oct 28, 2016 | 05:18 AM
redford's Avatar
redford
FTE Leadership Emeritus
Either exhaust manifold studs or a cracked passenger side exhaust manifold.
Old Oct 28, 2016 | 05:57 AM
Ron94150's Avatar
Ron94150
You could be on the verge of spitting a spark plug out. My dad had an 02 that developed a tick at @75k miles. It was intermittent at first, then continuous, then one day, it sounded like the right front tire exploded. And the truck started missing with a very loud lick. He thought he had broke a rod or something. It had shot out the passenger rear spark plug. Honestly, that's probably your best case scenario. The repair kit was @ $35 back then and took @ 45 minutes to repair, and some gorilla glue to repair the coil. Sure beats changing lifters or messing with corroded exhaust manifold bolts. But with your mileage, there's a good possibility of the valve train needing some attention somewhere. Could try some thicker oil or STP oil treatment just to see if it helps. That STP is good stuff.
Old Oct 28, 2016 | 10:13 AM
flyingtexan
So no cam phasers on my 02 5.4? Thought that would be the problem?
Old Oct 28, 2016 | 10:52 AM
Mike189677's Avatar
Mike189677
See above. Take a video and post it.
2004f250superduty
Jan 25, 2018 09:29 AM
kactus_kyle
Oct 30, 2017 05:09 PM
F350Man79
Jul 28, 2014 07:59 PM
JERSEYJOE2937
2004 - 2008 F150
Aug 25, 2010 10:53 PM
colin_r
2004 - 2008 F150
Dec 2, 2009 09:48 AM
