RV Glow adapter?
RV Glow adapter?
Anyone using one of these or something similar? I saw an exhibit at a RV show a while back where a dealer had 30 or so trailers using this and it seemed like a good idea.
RV Glow - Turn your outside camper lights into patio lights.
I am looking for a cheaper alternative, or even a DIY for the plug, but haven't found anything yet.
EDIT: It appears that if you jumper pins 3 and 4 on the female/trailer plug the running and marker lights will illuminate.
http://rvbasics.com/techtips/emergen...er-lights.html
Additional EDIT: It appears that this practice is frowned upon by other campers. I intend to only use this when boondocking and for short periods like before we crash for the night. I do not intend to use it in campgrounds or busy locations.
Don't know if anyone is so inclined, but they also make those strips of LED lights you can put in awning channels. I am not a big fan of mounting them there due to the plugging and unplugging that is required. but they look kind of nifty if you put them just below the awning on the side of the camper. That way they can stay plugged in and it often is not too hard to wire them up. I have installed those a couple of times for folks.
There are quite a few varities of these https://www.amazon.com/Recreation-Pr...g+lights&psc=1
Steve
Steve
Steve, I am currently researching installing LED lights for our awning. Since our new to us 5th wheel is a 2011 and a High Country, it did not come with LED's on the awning from the factory. I might resort to LED's mounted to the frame instead as they could be hardwired and I wouldn't have to set them up each time we camp.
I put together a handy 2x4 plastic box bolted to a spare truck end Pollak plug, added a fuse and a toggle switch then just plug the cord in. I didn't add the flasher as that is annoying to others in the CG, especially to folks with an inner ear/vertigo problem such as my wife. We don't have awning lights but it doesn't look bad on others rigs. Some lighting on RVs we've seen this year are, IMHO, beyond good taste.
Received 3,995 Likes
on
This is a Great Idea.........
I thought so as well. Just finished changing 100% of the lights to LED on the 5th wheel and ordered a flasher for the "just in case" factor.
I am looking to build a design for the lights to be on via a switch now. More to come.
Yes! No need to buy anything but a 10 amp fuse. Does exactly the same thing! I would almost bet this is exactly what the purchased item does but they don't want you to know this.
Resendiz
11-27-2016 11:19 AM
