Need helping on what engine is in my ford vanette? - Ford Truck Enthusiasts Forums
Old 10-26-2016, 04:53 PM
Adam Wareham
Adam Wareham is offline
Adam Wareham is starting off with a positive reputation.
hello not sure if this is in the correct spot since there is no ford vanette section. I have a 1959 ford vanette with a 4 cyl diesel motor that came in it. it is complete and would like to get running again. but i cant find any info on this motor or even vanettes. any help or a lead in to right direction would help. most had flat 6cyc gas.
Old 10-26-2016, 07:39 PM
matthewq4b
matthewq4b is offline
matthewq4b has a great reputation on FTE.matthewq4b has a great reputation on FTE.matthewq4b has a great reputation on FTE.matthewq4b has a great reputation on FTE.matthewq4b has a great reputation on FTE.
Not the original engine I believe it's look to be a Ford Dagenham or Dorset Diesel. These were English built and were commonly used in industrial applications in NA and Fordson tractors in the UK.
They were used in the P series also
Dagenham 3.6L 220 cui 1963-1966 P-3500/4000/5000s.
Dorset 4.0L 242 cui 1967-1970 P-3500/4000/5000s.
Dorset 4.1L 254 cui 1971 P-3500/4000/5000s.
You may want to try on one of the British Fordson tractor web sites those guys will be able to tell you if it is a Dorset or Dagenham as for parts your best bet will be a Ford Industrial Engine parts supplier or they will at least know what direction to point you as will the guys on the Fordson site.
Old 10-27-2016, 01:51 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Diesel engine has been swapped in. What is the 4th digit of your trucks VIN?
Old 10-27-2016, 08:43 PM
economan
economan is offline
economan is starting off with a positive reputation.
Verycool!
you planning to restore or rod it?
luv to see different things like this saved
Mikie
near ottawa canada
58 M-100 panel & 64 econoline p/u
Old 10-30-2016, 09:03 AM
Adam Wareham
im selling one trying to get the other running to hear it than the motor will be pulled and deciding on a cummins swap or just a v8 thanks everyone for the imput
Old 10-30-2016, 09:06 AM
Adam Wareham
still trying to figure that out also there is only a plate in the box on the right side. no vin plates like everything else
Old 10-30-2016, 10:35 AM
NumberDummy
The truck is registered by its specific VIN
Old 06-13-2018, 09:21 AM
Decades213
Decades213 is offline
Decades213 is starting off with a positive reputation.
Recently purchased this Ford P-350 Vanette.
Any info or decoding would be greatly appreciated!!
Also, we got the truck started but need a new injector/injection pump. The serial number on the current injection pump is P4665. Any idea on a compatible replacement? I need one for a 4cyl diesel.
Found this on engine head. Engine block has the number S340240. Any info on engine would be greatly appreciated. All I know is Fordson diesel tractor. ☺️
Old 06-13-2018, 08:57 PM
matthewq4b
The Engine is a Dagenham 3.6L 220 cui Diesel they were used in the P series from 1963-1966
The original Injection pump is a Simms inline.
Best bet it to have the original rebuilt, most of the industrial/agricultural injection pump re-builders should be able to rebuild it.
Simms/Minimec/Lucas CAV Pumps were used a wide variety of AG and industrial equipment, in North America such Companies such as Fordson, Ford /New Holland , Allis Chalmers, Massey Ferguson, Bolinder/Volvo used Simms in line pumps.
Any re-builder that does Delphi-Lucas-CAV injection pumps should be able to do it.
IIRC the Simms pumps had their own oil supply and it should be drained and changed when the engine oil is changed.
Old 06-14-2018, 07:27 PM
NumberDummy
No Fordson tractors were assembled in the US after the late '20's or early '30's, I've forgotten which.
Production continued in Canada and England as their governments didn't 'clamp down' on FoMoCo like the US Gov't did.
These tractors were man killers, would rear up, then flip over backwards.
G35 = P350 Parcel Delivery (Diesel).
4 = Dagenham 220 cid 4 Cylinder Diesel; 65 net HP @ 2,500 RPM
H = Lorain OH Assembly Plant.
472532 = 1964.
Old 06-14-2018, 11:51 PM
Decades213
Amazing!
Thanks a bunch! All of that info helps a lot! It was sold to me as a 1959 without a title and I wasnít sure how to decode the vin.
Any idea what any of the other numbers on the vin plate are?
NumberDummy, any idea how many people join this site just to connect with you?? Youíre kind of a legend! 😁
Old 08-23-2018, 09:35 AM
Decades213
Simms Injection pump
Thank you so much for your direction with the injection jump. I took it to a place locally that does Delphi-Lucas-CAV per your suggestions and they cleaned it up for me and replaced the lift pump on the side. Everything works as it should!
We put it in the truck and it spit diesel like crazy! 👏🏼👏🏼👏🏼 The truck started right up. Itís possible it was air locked or the lines a bit clogged up.
Thank you again!!
Gasoline
08-01-2017 12:37 PM
Tom Callan
1968-2013 Full Size Vans
06-21-2017 09:14 PM
Outlaw56
02-23-2017 10:23 AM
starbuck66
Large Truck
23
09-29-2016 09:56 AM
PARCEL DELIVERY
56
08-29-2016 09:54 PM
Quick Reply: Need helping on what engine is in my ford vanette?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
