Pinion turns but will not propel the truck.
Okay, I'm checking this out for my Dad who doesn't do computers. He has a 77 F-150 4x4 with an automatic trans. He was pulling a trailer up a hill the other day and suddenly lost power to the rear wheels.
Upon further examination, he found he could lock the hubs & get home with the front axle propelling him. You can jack the rear wheels up and turn the yoke by hand and it will turn the tires, however, when you set it back on the ground, the pinion will turn without turning the wheels (with some resistance). You can turn each tire and it will turn the yoke (it does have some kind of a limited slip differential).
He took the yoke off and the splines are okay, could it be the ring & pinion slipping (worn out), spyder gears ? We just would like to have an idea before opening the whole thing up.
on
Before pulling the axles, remove the driveshaft and with the truck on the ground and using something like a pipewrench , try and turn the yoke and whatch the pinion nut. You may have a stripped yoke and it's the easiest fix possible for your problem. I had 2 fail , the good part is the pinion shaft is harder than the yoke and the splines may be ok and you'll just need another yoke. You can do this with the driveshaft on but it's harder to see if the nut turns with the driveshaft or not. If this isn't it, your going in deep. Good luck.
on
How does it feel when you turn the gears by hand? and roughness , binding or skipping when you rotate the gear? It's hard to see the side gears but if the splines look good and gear teeth look good they should be fine. How did the axle splines look? You did check the yoke first right? If the yoke stripped the gears will all turn fine, feel fine and splines will be fine. You will not be able to make it slip by hand either.
The splines all look good, yoke, axles & differential. With the wheels on the ground you could turn the yoke with a bare hand. it had normal backlash too. There is no perceptible noise by hand or when driving the truck. Is possibly the gears or clutches in the limited slip unit that are offering no resistance?
