1964 F100 4x4
Theres something going on with that truck, its got a 2WD battery tray under the hood and also a 4x4 battery door in the floor...unless F100's came like that. Cant put a battery tray under hood of my F250 because pass side inner fender is different than 2WD. Or so it seems. I tried it, aint happening
There's something going on with that truck, its got a 2WD battery tray under the hood and also a 4x4 battery door in the floor...unless F100's came like that. Can't put a battery tray under hood of my F250 because pass side inner fender is different than 2WD. Or so it seems. I tried it, aint happening
It's a 4WD conversion, probably by a previous owner.
The seller posted the VIN: F10CR510720
F10 = F100 2WD / C = 292 2V / R = San Jose CA Assembly Plant / 510720 = 1964, assembled March 1964.
So is the seller aware? There's no mention of a 4WD conversion.
Looking at the right side view, the front wheels seem to be too far to the rear, are not centered in the fender opening.
Edit: There's a pic of the Warranty Plate, the VIN begins with F11 = F100 4WD .. but the Warranty Plate looks brand new (possibly a Marti replacement).
So, the only way to prove whether it was originally a 4WD, is by the VIN on the title.
After reading this post, I looked at the ad again.
F10 = F100 2WD
C = 292 2V
R = San Jose CA Assembly Plant.
446775 = 1964, assembled August 1963.
128" Wheelbase.
BM: B = Caribbean Turquoise / M = Wimbledon White.
F100 2WD .. 5,000 lbs. GVWR
C81: C = Medium Green Crush Vinyl & Medium Green Check Stripe Woven Plastic / 81 = 81B Custom Cab.
B = Borg Warner T-85 3 Speed Manual with Overdrive.
A2 = Spicer/Dana 44 Rear Axle / 3.92-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
C = 292 2V
128" Wheelbase.
Compare this Warranty Plate which looks like a "new Marti replacement" with the pic of the original Warranty Plate in post #8.
1964/65 US trucks used the same Warranty Plate.
As a general rule, worry about conversions when you see the newer '64-'66 styleside bed on a '64 or '65 F 100 4x4. Even without looking at a VIN #, most will not go thru all the trouble to locate the correct bed, cut the frame down and use correct steering wheel and column. I think the dual battery conversion is a great idea! Maybe it was a factory DSO job!
