FE valve cover gaskets
Old 12-18-2018, 08:22 PM
baddad457's Avatar
baddad457
baddad457 is offline
Summit's SUM-G3434 are the ones that'll work on the middle holes. Trans dapt 9640 should also work. Their 9067's should work on the corners.
  #32
Old 12-19-2018, 06:47 AM
the_hetz's Avatar
the_hetz
the_hetz is offline
In my experience, just putting some 1/4" washers is enough to keep the bolts from pulling through so easy once the covers are straight...haven't found a need for spreaders yet.
Also, I stick the gasket to the cover with silicone and use grease between the gasket and head/manifold, even where the dab of silicone is, so that they will come back off without any hassle.
  #33
Old 12-22-2018, 08:24 PM
69cj's Avatar
69cj
69cj is offline
Originally Posted by mrpotatohead
The problem with FE valve covers leaking is the metal on the valve covers is way too thin. It will not compress either cork or rubber before they start to bend at the bolt holes. It would help if the gaskets, either cork or rubber were softer. I am tempted to ditch the gaskets altogether and try some Motorcraft sealant in a tube that I use on 7.3 diesels.
good luck getting them back off
  #34
Old 12-22-2018, 10:45 PM
maxtor's Avatar
maxtor
maxtor is offline
Seams like I have installed a million valve covers and mostly for racing applications where the valve covers have to be removed many times for valve timing. My method and it works 100% of the time is to use cork gaskets and put gasket sealer between the valve cover and the gasket. On the bottom side of the cork gasket I use grease. Don't over tighten. No leaks, and easy to remove the valve cover for timing adjustments.
  #35
Old 12-26-2018, 05:45 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
That has always been what I do also.
ford66
08-09-2009 08:54 PM
flying4fish
15
04-09-2009 09:38 AM
1962_Fords_rule
01-13-2006 10:20 AM
74fordtruck
15
11-16-2004 02:47 PM
sickly 302FI
04-02-2004 10:12 AM
Quick Reply: FE valve cover gaskets
