Fiberglass novice
Fiberglass novice
I.ve done a little body metal work but have little experience with fiberglass (I did build the glove box in my TR-3, But that's it). The bedsides of my Ranger Styleside are fiberglass and I want to cut and form vents in the fenders, fill the stock tail lights and replace with ones I will build, and make or modify the roll pan. Before hitting the truck with the saw, I want to learn as much as I can. I've been searching the net and have been to the local library - any suggestions?
Dono
Dono
Fiberglass novice
Sounds like a good idea. Only suggestion I would have would be, are their any vents premade that you like/ would fit what you are looking to do, with the import craze there are a lot of vents to choose from. It would be easier to bond a premade vent than trying to sculpt it. I would recommend welding in a metal filler for the rear lights as opposed to fiberglassing it, always have that possibility of it cracking, however on the stylesides that would be fine. I would opt for the steel rollpan as well and have it welded. Good luck, would like to see your final results when you get it done, sounds interesting
Fiberglass novice
dadgonebroke
18
10-12-2016 09:23 PM
jniolon
15
08-31-2011 10:49 PM
