lincoln 337 few questions
Old 10-21-2016, 03:57 PM
Autumn's Avatar
Autumn
Autumn is offline
Hi every one im looking for help everywhere i can . Maybe somebody can aswer me on few question.
1 wich care came from this set ( engine and transmission) cosmopolitan?? because i want buy some service manual ( i cant remove cam shaft, which is snaped on 3 pieces)
2 i need few parts can some body recomended me shops online where can i get it ( cam shaft, piston rings, gaskets, fuel pump, crankshaft berings)
3 what is the best way ignition converion ?? ( 12v alternator)
Old 10-22-2016, 03:01 AM
big job's Avatar
big job
big job is offline
Easy questions- there are fuel pumps Expensive on ebay (i need one too so I run
electric pump) gaskets are also on ebay. Kanter in NJ most likely can help with
bearings etc. one wire alternator, new 12vt coil and resister (your 6vt starter will
work fine with 12vts)..
Hard question; broken camshaft >how in the world< did that happen?
Next does it have hydraulic lifters? because I don't know if a solid lifter cam will
work I'll check on that. Or Chucks Trucks LLC he's a member here....does this
help a little. sam
Old 10-24-2016, 12:21 PM
Autumn's Avatar
Autumn
Autumn is offline
Thans for reply !!
Maybe you know which car that set come from, because i dont know wich service manual i needed. ( for bolt torque, wire diagram etc.)
I thing sombody tryed start up the engine after long time when valves not moving that why snaped. because nothing more damaged. lifters looks perfect but 3 of them i found in sump :
Kanter is some guy ?? or some parts shop ??
por 12v conversion i need new aleternator or can i use my gnerator 6v for conversion too ??
What about ignitio system?? can i bou some set ( dustributor, coil, module exactly for my engine ??
Old 10-24-2016, 01:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Kanter Products: https://www.kanter.com/
Your engine has an automatic trans, so it is clearly a Car setup, not from a truck. There are differences between Car and Truck 337's. Honestly, your best bet is likely to be on the Ford Barn, Early V8 (1932-53) - The Ford Barn
You should mention you are in Great Britain, there are members over there who may be able to help. That engine/trans are difficult to find some parts for, more so over there I suspect.
Old 10-26-2016, 03:45 PM
Autumn's Avatar
Autumn
Autumn is offline
Thank you everyone for help! i gonna writing on early v8 forum cheers
Old 10-26-2016, 08:32 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Autumn
Thans for reply !!
Kanter is some guy? Or some parts shop?
Fred & Dan Kanter of Morris Plaines NJ got their start in the parts biz by selling NOS Packard parts at swap meets and in Hemmings Motor News.
But it wasn't too long after, when they began selling all makes of parts, because there were just so many NOS Packard parts to go around.
Old 10-27-2016, 08:10 AM
abusek's Avatar
abusek
abusek is offline
Not sure value but I've seen 2 of these come up in the last week. Other one seems to have sold for almost $1000 more but was total rebuild.
https://corvallis.craigslist.org/pts/5807199675.html
Old 11-18-2016, 03:46 PM
Autumn's Avatar
Autumn
Autumn is offline
thank you but i need parts for rebuild my one , and most important is cam shaft .
Old 11-23-2016, 01:23 AM
big job's Avatar
big job
big job is offline
I found a cam shaft new in Ford box 'forgot I even had one' anyway Its
a 8EQ and I have no clue if it is compatible with hydraulic lifters or not.
I do know some trucks had hydruaulics. There is no mention in the books
It shows only part numbers on both lifters and a part number on the cam.
I'll take a pic today for you.
sam or email me at Visicoach@comcast.net.
Old 05-04-2017, 11:40 PM
Hotrodrpu's Avatar
Hotrodrpu
Hotrodrpu is offline
Sam I have the parts you need hotrodrpu@yahoo.com
4drocket
05-03-2019 01:58 PM
Autumn
10-21-2016 03:37 PM
McYondan
01-27-2011 12:37 PM
bobby738998
05-18-2009 10:38 AM
spaceganja
1978 - 1996 Big Bronco
11-12-2003 10:29 PM
Quick Reply: lincoln 337 few questions
