Just What You Want to See... Another '53 Build
Not much "rebuilding" to report, just driving the old boy. More than 200 miles and only stranded 3 times. Out of gas, plugged fuel filter, and an unsecured radiator cap, but a good friend once and a very understanding wife twice, came to the rescue.
Will soon get down to disassembly but really torn on how to proceed. Originally I was going to take it all the way down and do a full restoration... now I'm considering just doing the mechanicals and leaving the body as is ... at least for now???
Got to say driving this thing and spending time here on this forum learning, is more fun than I've had in a long time... thanks !!!
Welcome! very nice truck you have there. Sounds like you have had a short season this year and full restos often take a lot longer than you think so if I was you I'd tend to some basic mechanicals and minor upgrades like disc brakes and the wheels and tires you want and maybe pull the gas tank and clean it out and then try to drive those new wheels off it next summer. P.S.I grew up in Sparta so I notice with interest all you Michigan boys and your projects and I know your pain with rust thru. Here in Oregon our cars die of old age or simply the lack of someone to want to do some mechanical work long before they accumulate any rust. My daily driver is a 88 Plymouth minivan and the only rust is on the roof where the original paint has failed and the rattlecan primer wears thru.
Been slow going with any major accomplishments on "Henry", mostly because I've basically made him my daily driver..
A few little additions like new wiper arms and blades, a heater distribution box, and one new striker plate for the drivers door. Major frustration has been wheels and tires.
Just wanted something to get me through the fall and found a set of used 6.50-16 bias ply take offs pretty reasonable, so had them mounted and balanced. They were horrible to say the least. They had a low speed thump in them that made driving around town very uncomfortable. The original tires did that too but not as bad so I determined that it must be the wheels.
I found a cheap set of 15" wheels and radial tires off a Hot Rod, I through on for nowand she drive like a dream in comparison.. Front are to small and the backs to wide but they will work for now...
Opinion question for all... The new rears are about 27.5" diameter, a bit shorter than the 6.50-16s. The calculated engine RPM is 2650 at 55mph and that seems pretty close, maybe a bit higher, with a make shift tach I hooked up.. Anybody think thats too much for an old Flathead to run at cruise?
Going through these calculations myself as mine has 4.27 gearing so I would like to see what others say as well.
I did find some of these charts which makes seeing it a little easier.
Gear Ratio Guide - Gear and Tire Diameter Ratio
4Lo.com :: Gear Ratio & Tire Size Chart
Hanger53,
Man that is a sweet looking 53! It just looks so solid! Glad your having fun with the truck and one here too. (I just joined today). Your truck looks like something I would drive too! I didn't know you could still find them like that?
As far as a complete tear down? That's up to you? Lots of work and dollars, but it can be very rewarding work too.
These forums are part of my therapy also!
Regards,
Chris
Regards,
Chris
Latest "Henry" update:
Had to put him on the back burner for the winter as another project took priority and longer than expected. Got him out this spring and ran just as well as the day I put him away.
I've decided to leave him basically as is and run for the summer before starting any major work.I need to do the electrics for sure and would like to install a Dual Reservoir Master Cyl. but keep the front drums for now.
I bought a complete wiring harness, (12 volt, neg grd) and tomorrow all the 64 yr old wire will be in the trash can!! Got the new harness played out on the floor and all tagged but it is still a little daunting to know that it's not going to run again until get this installed correctly...
Found a master cyl kit from a place called performance on line. It looks pretty good but know nothing about. Could not find anything at LMC or Mid-Fifty that worked with drums. All were for disc conversions..
Any suggestions?
Any suggestions?
You will need to "tee" the master cylinder output for the front brakes. The original MC has three outputs. One for the rear and one each for the left and right fronts. The new MC will have one for the rear and one for the front.
Edit: Added picture
Thanks Greg, it's a good old truck but a bit of a 50 footer, some old body work wasn't done very well and some rust in the Cab. The longer I have it the less inclined I am to do anything but drive it!!
Hope to get down to the Supernationals, don't have my kitchen pass yet
What town are you located? You should try to make the Lane Automotive Memorial day event Lane Automotive Car Show and the Kalamazoo Street Rod Nationals in September. Both great events if you live in this part of the country!!
BTW I love the Olds Convertible!!
