Towing Heavy with the 6.2
on
*** Weight Police - please skip this thread ***
Curious who is towing 15k or more with the 6.2.
What gearing are you running, any mods, how does the truck do?
I realize that these are not diesels and will suffer in the high elevations and steep hills.
Let's hear your stories please..
I second this.
my truck, 800 pound motorcycle, trailer and stuff is a total of 17,000 pounds (scaled)... with 3:73, it does OK,, but hills is Second gear and 50mph.
so your 15k trailer, and a 7k truck, you, others, fuel, stuff.. could equal 22,000 total or more.
We have a 2013 F350 DRW SC 2x4 6.2 with 4.30 gears that pulls our 16K 5th wheel. Towing when averaging over a long tow it will get 8 to 9. The low end is when we are running 2 lane and the high end is all interstate. With everything full including the 50 gal aux tank we scale at 24.4K.
We have pulled this trailer over high mountain passes the highest being 11,300 ft (Wolf Creek Pass) and just like any motor it will slow down (even diesels) but with the 6 speed and the ability wind it up it did just fine but in lower gears, if I remember it was in low doing 25 mph at the top, it would have gone faster but I didn't want to push it. On flat roads it will pull 6th most of the time with downshifts to 5 and sometimes 4th on overpasses in cruise, if I don't use the cruise it will hold 6th by letting the speed drop. Off the line this motor is very impressive pulling a load and down right scary when empty with the 4.30 gears. Cruising down the road at 65 it runs around 2K rpm and you can't here it running but if you jump on it then it sounds like a old fashion muscle car .
Coming from a 2V V10 with 4.30 gears it took a little getting used to but after the first hard pull I was sold. The dive by wire was the hardest thing to get used to.
Denny
Denny
12,000 lbs.loaded trailer weight with signature rig...3.73..does the job...4.30 would be better. Got over 7000 towing miles behind the Ford now.
The biggest problem I have with the 3.73 being that i have a high profile trailer, with a headwind going 65 mph down the interstate, 5th is too tall and 4th is too low of a gear. I'm talking about winds over 10-15 mph on the nose.
Denny
Stopping has never been good with the trailer...so I thought that was a better investment at this time
I just bought Timken bearings for my truck but can't find any real info on late models on if there is a torque spec or if it is done by feel. Have you found anything?
Denny
