Hello, my 67 2 wheel drive pickup came out original with a manual transmission but when i bought it the transmission had been changed over to a automatic (C6) but the rearend gear for the manual transmission still in it.Cant find a tag on it. Everything works fine but i now have the truck back together and Im going to have to change the rear gear because running 65 to 70 mph Im turning around 3800 to 4000 rpm. On the manual transmission trucks did they offer more than one gear ratio ? and what gear ratio are most of you guys running with the 390 C6 combonations ? I had my motor completely gone thru with everything new except crank and block.I would like for it to turn around no more than 27 to 3000 rpm at 65 mph. Any sujestions on what gear to use without killing the take off ? And what was the more common gear that ford used with the automatis trucks in 67 ? Thanks
F100 or F250? Top gear with a manual or automatic is 1:1
Remember, these rigs were built when 60 MPH was the norm... and these were built to work. Crappy aerodynamics because again, these are workhorses.
Do you have a tachometer? A 4.11 rear gear is what I was guessing but if you're really turning 4000 RPM then like 5.38.
No tach? Then you're providing bad information....
My 3.70 gears with 30" tires is about 3000 at 70 mph by GPS ( about 75 on the speedo). You must have really low gears, or really short tires! I ran 4.11's in a car with 26" tires for a short time. About 3700 at 70. It was a pain on the highway, but man it would scoot from a redlight!!
Post the axle code off of your door tag if the tag's VIN matches your recorded VIN. That way we get to see what the original ratio was as a starting point.
3:00-1 will keep you in that 2300 to 2100 rpm range at 60 MPH ( 26 to 28" tire size)
3.25-1 will keep you in that 2500 to 2300 rpm range at 60 MPH ( 26 to 28" tire size)
3.50-1 will keep you in that 2700 to 2500 rpm range at 60 MPH ( 26 to 28" tire size)
Should give you a base to start from. 3.00-1 Gear sets are pretty common in the wreckers in cars from the 70's
If you have 10% converter slip in a stock TC time to replace it, it should be 4% to 7% for a stock TC, 10% is getting on the lose end of things even for high stall drag converters.
And that is why it was range and not exact numbers.
ru67, Sounds like the truck may have come with the small 240 6 in it. Couple suggestions, get a app for your phone that will give you correct mph. I think I have both digiHUD and car performance. Both can use gps for actual miles per hour. The other is to get a bud and on your garage floor or very level ground hand roll the rear wheel 1 complete revolution while counting the revs of the driveshaft. The bud is just for safety and help with the counting. I like using a Sharpie to make makes on both. Since this is reverse action it gives you the actual count for your correct ratio your truck is set at.
Yes, but I find 10% to bring more accurate numbers.
As another baseline, with 2.75s and 31" tires, with a locking TC. I run right at 2000 @ 65.
John
Keep in mind, If only one wheel is turned, the driveshaft rotations will be double what the ratio is, because of the differential.
If I get a chance tomorrow evening after work I will jack it up and turn my rear wheels and count the rotation of the drivepole and also measure the height of my rear tire. thanks
In dealing with a vehicle that's nearly 50 years old, anything could have been done/changed on it. 3rd members are one of those things that isn't terribly difficult to change out for some other 3rd member with a different ratio.
Unfortunately, when something like this is messed with, many people are too lazy to put that little gear ratio tag (that specifically goes with the particular 3rd member) back on the stud before installing the nut.
Doors can be changed too, which would make the info on the warranty tag bogus.
If either of these things are not known to be original to the truck, there's only one sure way to verify what the rear end ratio is with 100% accuracy --and that's to pull the 3rd member out of the housing, count the number of teeth on the ring gear and the number of teeth on the driving pinion, divide the number of teeth on the ring gear by the number of teeth on the pinion and you'll have your exact ratio.
The final drive gear on the manual and the c6 is the same so the engine will turn the same rpm with either tranny. I'm doubting your turning that many rpm's. I'm guessing your speedo may be off. That's a lot of rpm for 65-70mph. You would need a 4.56 or so to turn that.
