Crank but no start
Crank but no start
Hey guys. Having an issue with my RC flatbed dually: it will turn over but not firing. So far I have replaced the CPS, and ICP (Had a code for it when I got it started the other day, but now it won't start again). A couple of weeks ago it was having no issue starting but one day it just wouldn't start, it was a week before I got a chance to work on it and the middle of last week I got it started. Today when I went to start it it is just turning over again... any ideas? I need to check the FP and HPOP reservoir oil level but will have to do that when I get off of work tomorrow. Any other things I should check? Thanks for the help!
on
1 Post
Get the batteries load tested. The PCM has to see 10 -10.5 volts before it will tell the IDM to fire the injectors. Just for a quick check, check voltage while cranking at one of the batteries with a volt meter.
I checked the voltage while cranking (11.4) and had them load tested... they both tested good. For once the problem actually came up when I was at the auto parts store (only it just clicked... dead, nothing. It didn't turn over at all) I didn't get a chance to change it out last night but the passenger side cable end on the ground seems like it's not getting a good connection. Could that cause the issue possibly?
Bri...111
12-21-2015 09:41 PM
thesnowboarder
19
12-19-2011 12:56 AM
