Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Surge, miss, lunge, spit, sputter
Old 08-22-2003, 11:07 AM
mimsand's Avatar
mimsand
mimsand is offline
I have 1999 lightning PU. At low speed, between say..... 25 and 45, and under no load, just puttin along, it will seems to miss and surge. No real ryhme or reason. It is very prevailent after a fill up. At times the Service Engine light is on for a day or two.
Never dies, just jerks to and fro.
M
Old 08-24-2003, 05:55 PM
Aerodyamis's Avatar
Aerodyamis
Aerodyamis is offline
have u checked the spark plugs
Old 08-25-2003, 08:12 AM
mimsand's Avatar
mimsand
mimsand is offline
No I haven't.
Has 42,000 miles. Is it time>??
Old 08-25-2003, 08:24 AM
luckild's Avatar
luckild
luckild is offline
pull the codes and you will get more help.good luck.
Old 08-26-2003, 09:24 AM
mimsand's Avatar
mimsand
mimsand is offline
Does anyone have instructions on getting the codes from a 99 Lighning?
Had a '90 F150 and the code reader but, no idea on this one.
Old 08-29-2003, 06:31 AM
mimsand's Avatar
mimsand
mimsand is offline
OK.. figured it out.
Took it to Auto Zone and had them read the codes. 1 code stored. Excessive EGR Flow. Disconnected the vacum line to the EGR valve and reset codes. Truck ran much better. Service light came back on, had codes read again. 1 code, insufficient EGR flow.
Removed and cleaned EGR with carb cleaner. Will let you know but it seems to be cured now.
Old 08-31-2003, 09:43 AM
Bullitbike's Avatar
Bullitbike
Bullitbike is offline
mimsand, read my post on HD cure. May need to check dpfe sensor. It works with egr. Ford dealer here keeps many because it is a very weak link in all model Fords.Hope helpful. Rudy 03'HD, 2000 EXP., 96' Cobra, 94' f150 4x4, 2000 zx9r
Madmooner
Modular V10 (6.8l)
07-27-2016 09:46 PM
wtroger
03-09-2016 10:48 PM
wtroger
2004 - 2008 F150
03-09-2016 10:40 PM
cjfarm11
79
01-27-2011 11:26 PM
wrecksfixed
1997-2006 Expedition & Navigator
04-15-2008 11:14 PM
Quick Reply: Surge, miss, lunge, spit, sputter
