Also, When finished, wash out the Ford nozzle. The DEF can crystallize and it will not flow properly. You might think the tank is full when it isn't. I wash mine out after each use with some sterilize bottle water.
can 1 of yall post a pic of this. I'm at 5600mi and my OBC says that I'm under 1/2 full. So I know that I will be refilling soon. I'm waiting till the pop-up tell me I'm at 500mi till empty before I refill.
I had a problem earlier in the year when my DEF tank wouldn't take fluid even though it wasn't full. The Ford spout let me lock it in place and then use the pressure to fill it. No idea why it has blocked but it hasn't done it since. I was away from home (where I'd left the Ford spout) so I had to buy another.
Great info. Didn't even know Ford offered this. I have spilled DEF fluid before and scrambled for the hose before it ate down to the metal.
Just ordered it off Amazon and look forward to not having that issue any longer.
