Old mans 55 F350 build - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 03-26-2017, 08:56 AM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
Looking great. Firing the long slumbering engine up is pretty much the second best feeling ever!
  #32
Old 04-02-2017, 09:45 PM
Silver54's Avatar
Silver54 Silver54 is offline
Silver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to beholdSilver54 is a splendid one to behold
Well today was the big day, first attempt at firing the old girl up, gave it a few CCs of fuel down the carb and cranked it over. Must have only rolled over once or twice and then it coughed and barked. Fuel pump primed up nice, and it fired right away. Let it run and idle for about 15-25 seconds and then shut it off. Now it's time to finish the engine. Water pump is going to go out for overhaul, fuel pump is going to get a new diaphragm put into it. Then we can run it long enough to fully set the valves and rockers. Looks like this build is going forward nicely!
If I can get a video of it running then I will put it up for you guys.
  #33
Old 04-03-2017, 11:20 AM
Silver54's Avatar
Ok let's test this and see if the video actually works
https://m.facebook.com/story.php?sto...3&id=509261354
  #34
Old 06-07-2017, 08:11 PM
Silver54's Avatar
Ok so it's been a while since the last update, still on the road so can't get too many new picture.. got one cab corner patched up. A new fuel pump, get the water pump back from the overhaul shop. New thermostat. And new hoses. Pulled the seat out and cleaned up the inside.
Get back to town Monday, so I will try to get some more updates put up. Should be able to have the engine bay done soon and start the re wire project on it. Dad is planning on working on the brakes and axle swap at some point soon too. Should go quick if we can get the shop time.
  #35
Old 06-07-2017, 08:43 PM
df85732's Avatar
df85732 df85732 is online now
Secret Agent
df85732 has a good reputation on FTE.df85732 has a good reputation on FTE.
Looking good Jason! Keep plugging away!
  #36
Old 08-12-2017, 01:39 PM
Silver54's Avatar
Well guess it's been a while since the last update. Haven't done so much for Visual progress but still plugging away, got that R/H fwd corner finished, closed up and sprayed. Been getting tired of having to pull the battery and set it up every time I want to run the truck so I decided to fully install it. So now the ignition and start button are hooked up as well as the throttle cable, accelerator and choke controls. Then I had to run it... of course to make sure that the ignition and push button actually work, and since it was running then it only made sense to rig the valves and secure the valve covers with new gaskets.
With the truck now running nicely it was about time I got busy and install the airfilter, but as this had the air oil bath I didn't have anything to install. So I bought a filter at Canadian tire and make a housing to hold it.
And here are some pictures of how the housing turned out.
And with a little added paint and some wing nuts to finish it off
  #37
Old 08-12-2017, 08:21 PM
way2rod way2rod is online now
way2rod is starting off with a positive reputation.
Looking good!
It's amazing how much time all the little things take, keep plugging away!
Zac
  #38
Old 08-12-2017, 08:45 PM
dcavan001's Avatar
dcavan001 dcavan001 is offline
dcavan001 has a very good reputation on FTE.dcavan001 has a very good reputation on FTE.dcavan001 has a very good reputation on FTE.dcavan001 has a very good reputation on FTE.
That is great progress. I missed the last update -the cab floor looks pretty good. Glad to see you sticking with it.
  #39
Old 08-13-2017, 06:28 AM
Silver54's Avatar
Thanks Zac and Dave! Appreciate you guys following along!
  #40
Old 08-13-2017, 10:33 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
What kind of fuel line is that? Does it have a wrap around it, like some brake lines?
  #41
Old 08-13-2017, 01:04 PM
Greg Rogers's Avatar
Greg Rogers Greg Rogers is online now
Greg Rogers is gaining momentum as a positive member of FTE.Greg Rogers is gaining momentum as a positive member of FTE.
Nice job! I love that you got the old engine running and didn't spend a fortune on a complete rebuild- (though I bet it still added up)
  #42
Old 08-13-2017, 08:54 PM
Silver54's Avatar
Hey Ross, the wrap on it is to keep from collapsing the line while you bend it, (can do it by hand with this one.). But yes, it's just a universal line that could double as a brake line. And all in all I think the engine gasket kit was about 100-200 (dad bought it so unsure) and as for most of the rest of the parts I think there may be another 200 into it. So even on the high side 400 total in the engine to get it going again is pretty decent. (Of course I am probably forgetting about some parts.) thanks for following along though guys!
  #43
Old 08-13-2017, 09:35 PM
df85732's Avatar
Secret Agent
That's awesome Jason. After seeing the cost of your dads engine I'm having second thoughts about rebuilding my engine I'm sure it will be worth it in the long run. I like your air filter. I never could understand the oil breathers and how they work. I should Google it somtime. Any updates on the rear end saga? Keep up the great work. Dave
  #44
Old 08-13-2017, 09:42 PM
abe's Avatar
abe abe is online now
abe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant futureabe has a brilliant future
In layman simplistic terms, oil bath aircleaners work like this. The air is sucked into the aircleaner. As the air goes around the bend in the aircleaner it slows down. When the air slows down it drops any dirt and particles it was carrying. They drop into the oil which hold the dirt.
Please add or detract from this explanation of it needs it.
  #45
Old 08-13-2017, 09:57 PM
df85732's Avatar
Secret Agent
Quote:
Originally Posted by abe View Post
In layman simplistic terms, oil bath aircleaners work like this. The air is sucked into the aircleaner. As the air goes around the bend in the aircleaner it slows down. When the air slows down it drops any dirt and particles it was carrying. They drop into the oil which hold the dirt.Please add or detract from this explanation of it needs it.
Does't sound like a perfect system, but then again some of these engines have been around for many years. Thanks, Abe
New ford heavy duty mud flaps ssoundwave 2017 Super Duty 143 08-04-2017 07:40 AM
'55 panel build sstephanuik 1948 - 1956 F1, F100 & Larger F-Series Trucks 159 07-31-2017 10:52 PM
56 "big job" wrecker...... Fat Gav 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 05-07-2017 11:55 AM
2017 f150 lariat canopy, bedrug Native Images 2015+ F150 9 02-13-2017 07:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
