1981 custom F150 heavy half wood truck
These came stock with 15 inch rims, 5 by 139.7 holes with about a 3 5/8 center bore not sure on the offset. I want to put a good used set of 16 inch rims so I can run a load range tire . Any options besides after market? I believe Dodge Ram 1994 are 16 inch same hole pattern not sure on the bore or offset.
I also have access to some free 1981 ford 250 rims which I believe are 16 inch but 8 hole.... if there is room to drill my bolt hole pattern that maybe an option ? thanks
Have you looked in the 15" tire size for LT (Light Truck) tires?
http://www.tirerack.com/content/tire.../homepage.html
Tire rack list XL (Extra Load) LT tires
Dave ----
Dave ----
Contact this ebay seller and ask them to measure the center bore: Dodge RAM 1500 Pickup Factory Steel Wheels Rims 16x7 1994 2001 | eBay
sweet
those are sweet I'll look for some local !
Here's a set of 16x7 5x5.5 cheap steelies - https://www.amazon.com/dp/B00E5JEO3Q - center bore appears big enough. Zero offset. At 7" wide you'll probably need a 265 or 275 tire, which may cause clearance issues.
Load range D
I can usually get dry standing so thinking load range D
Load range what? Guessing you want D or E....
That's a sweet tire
That's the only load rated 15 I found as well .
I would not cut the center out. It will weaken the wheel around the center. That turned up portion around the center hole is punched out and adds a lot of strength in that area.
Russronning
10-08-2012 09:49 AM
rebocardo
10-07-2002 02:13 AM
