Differences Between a 1990 and 1992 4.9L Straight 6
Differences Between a 1990 and 1992 4.9L Straight 6?
-The 90 Was an Auto f250 With Ambulance Package
-The 92 is a 2wd 5speed f150
I am curious if there are any differences when it comes to the electronics and fuel injection/emissions related stuff that should be swapped over from the 92 motor to the 90 motor.
The starter motor may be different as well. I don't recall the exact year split but the older one may not have the PMGR whereas the newer one will. They're compatible. You just need to run an extra wire to use the PMGR.
Some wire colors may be different. The engines are fully compatible otherwise.
CaptainIPSC
12-27-2011 02:22 PM
dpayne1976
02-23-2008 06:20 PM
