Oil leaks questions
Oil leaks questions
Went to a mechanic today to diagnose where oil is leaking from. He used dye to find leaking areas.
1) Oil pan gasket
2) Oil filter adapter
And I have a leaking power steering box.
Truck; 1995 F350 7.4 460 gas motor, automatic with 164,000.
The leaks are pretty minor. To repair they are saying the entire engine needs to come out. So the minor repairs are actually a big job. Their recommendation is not to fix it.... Is this sound advice?
thanks
1) Oil pan gasket
thanks
In my opinion, small leaks could very well lead to larger leaks, which could lead to a serious issue. You may notice these leaks now, but if they worsen at the wrong time, like on the highway, then you could end up with a costly mistake by overlooking these so-called minor repairs.
Best of luck to you.
When I got my truck from my dad the oil pan gasket was leaking. I simply checked to ensure the bolts were properly torqued. They weren't and the leak stopped once they were tight.
I'm not sure if your mechanic checked them but it worked for me.
In my opinion minor leaks always occur with vehicles over time. You and Klondon are both right. One can leave them and monitor them and sometimes they do get worse. Occasionally they get worse rapidly.
And leaks tell you they're not empty!
But really, the pan gasket on a 97 351w is a one piece rubber gasket. Not likely it's going to catastrophically blow out. As stated the pan bolts might be a touch loose. The oil filter adapter can be fixed in the truck, and its under oil system pressure so I'd consider fixing it. Good time to eliminate the oil to water oil cooler too. Then you can run an FL-1A instead of the puny FL-820S.
Edit: not enough coffee. I see now you said 460 not 351w, ignore my technical info.
Leaks
Leaks out of curiosity what did it cost to have the mechanic locate your three leaks.Don't answer just click on my home page video and check out the ultimate automotive leak detector that you could have hanging in your garage so after those three leaks located you could use this tool any time you want to locate leaks from bumper to bumper in the automotive system.
Leaks
Just for your information Even I am a seller I this site did't mean to bother you but smoke is the number one method of locating a oil leak power steering leak and if you would have went to my profile and read the description of the tool you might just have a different opinion. And your rite as a vendor I do get notification of leaks of all kind that my provisional patented tool can and does every day solve all leaks and to prove it to yourself click on my logo Ultimate Automotive Leak Detector and on the drop down you can check out my home page video and my profile both may just open your eyes to leaks and the ease of location.
Leaks
F350GK
Freshman User sorry For getting the name wrong like I said I do as a vendor do get notifications of all leaks since my tool doesn't fail to locate leaks.I have a provisional patent and have wen't to locate and help folks as yourself save money on the location of leaks since there very easy with my tool to locate.
I watched your video and read your description. It's a smoke tester that also has the ability of adding oil dye. As for looking for leaks in oil and power steering, the dye alone is enough to easily find the leak. I'm not bashing on your product. Smoke testers are wonderful devices, I use them quiet a lot at work. But when it comes to finding an oil leak nothings is as simple and as quick as a steam clean of the engine, some dye and runtime.
Tod1985F250
01-28-2009 06:42 PM
alkazoo
10-14-2004 08:16 PM
