67 f100 352 build
So I decided to go ahead bore the 352 out to std 390 and survival 445 kit Edelbrock heads intake, msd ignition and efi tub setup, behind that is a tko500 and it’s an awesome setup, she fires up instantly and is a blast to hear, soon I will be taking her out for a spin thanks for the help
BTW, thanks for the follow up!
I did the build myself except the machine work, I’ve done the break in but not yet dino’d Still a bit nervous, Barry is very good and it did take a long while to get all the parts but well with the wait hopefully the truck will be completely done bye spring but drivetrain is complete working on interior now
I know the trend these days is taking an old car or truck and putting a modern computerized fuel injected engine and drive tran in so one has a classic automobile with all the modern conveniences.
When ever I look at a old car and see a modern engine all covered up with some custom plastic or billet panel trying to cover up all the wiring and fuel rails I walk away disappointed.
I've always looked at the paint and wheels as the cool factor and the engine as the wow factor, can't get better wow than a mulity carbed or blown big block
Modern engines can make more power and get better fuel mileage but just don't have the WOW factor of a neatly dressed older engine.
I'll never give up my 406 FE with three Holley carbs for the modern convenience of computerized fuel injection.
It's nice to see a build actually happen, not just get discussed.
You can use the stock bell with a 1" spacer if I'm not mistaken. The TKO's fit the Ford "Cobra" and SROD bell's which are 1" deeper than the Toploader bells
Keith Mitchell
03-08-2017 04:48 PM
arex
08-04-2013 01:17 PM
Ohiocrewcab
02-19-2012 01:04 AM
