Holley 4150 choke high idle question when warm
Old 10-04-2016, 06:06 PM
ktm4012's Avatar
ktm4012
ktm4012 is offline
ktm4012 is starting off with a positive reputation.
I bought a new Holley 600 CFM 4150 with electric choke for my 79 ford F 250 with 400 engine. If I start the truck cold the choke works as it should and after driving 10 or so minutes it runs fine off choke. When I restart the truck after stopping for gas or food it goes back on high idle even with the engine temp at 180 degrees. Should it go on high idle even on a hot day fully warmed up every time i start it? I don't remember my last 600 doing it. Thanks for any help.
Old 10-05-2016, 01:17 PM
Beechkid
Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
it shouldn't......
Old 01-20-2017, 06:16 PM
lee
lee is offline
lee is starting off with a positive reputation.
Hi,
My truck does exactly the same thing.
The bi-metal strip inside the choke cap starts to cool as soon as the engine is switched off thus contracting and putting the choke back to "hi idle".
There are different ways I have seen Ford counter this. Some engines had a heater hose go up to a clamp on the bottom of the choke cap keeping the cap assembly warm at shutdown. I have also seen some engines where a small metal tube connected the cap and an exhaust source drew in via a vacuum. This warmed up the entire cap assembly.
Also, most intake manifolds have a heat crossover runner built in them that allows warm coolant to flow and heat up the entire manifold. This helped keep things warm.
Now on my engine, I closed off the crossover on the Edelbrock RPM manifold and I have no heater hose to a clamp, or small metal pipe to a vac source so,.... the choke cap bi-metal strip cools QUICKLY.
It's just a small pain in the butt ,... I choose to live with.
Old 01-23-2017, 12:42 AM
wdfp
wdfp is offline
wdfp is starting off with a positive reputation.
Choke could just be set too tight, Back it off a little and see if that helps. It should.
Kyle Wood
01-28-2018 11:59 PM
lalberts
15
12-24-2017 06:56 AM
chiefsfootball
16
03-28-2017 01:40 PM
Mutilator712
16
10-16-2016 08:46 PM
ktm4012
10-05-2016 08:17 AM
Quick Reply: Holley 4150 choke high idle question when warm
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
