Tire wiggles
Old 10-03-2016, 07:25 PM
Glowplugger's Avatar
Glowplugger
Glowplugger is offline
Tire wiggles
Changing Skippy's tire today (1999 F250) I noticed I can grab the front tire and wiggle it about 1/4" side to side. The other side wasn't that way. What should I look at throwing money at to find out the problem here?
Edit: The wiggle "play" seems to be in a grease fitting on a little bar on the driver's side if that makes any difference. I'll try to post a pic in the morning when God turns the lights back on haha.
Old 10-03-2016, 08:07 PM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
Choose your part.
Old 10-03-2016, 08:20 PM
Glowplugger
Best pic ever!!! Thank you!
It's where the drag link connects to the pitman arm.
EDIT: No, I'm wrong. THat's to do with the steering parts. You see where the drag link connects on the left and has a grease fitting? It's that part, but on the driver's side. It isn't shown in this pic.
Old 10-04-2016, 04:34 AM
Tugly's Avatar
Tugly
Tugly is offline
Ball joint? Common ailment on a vehicle over 150 K miles.
Old 10-04-2016, 04:35 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
Sounds like ball joints to me
Old 10-04-2016, 07:10 AM
Rikster-7700's Avatar
Rikster-7700
Rikster-7700 is offline
I thought ball joints were play at top and bottom? Wheel hub bearings were usually the cause of side to side play (steering parts aside)?
Old 10-04-2016, 07:16 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Sounds like the drivers side tie rod end.
Old 10-04-2016, 12:52 PM
Glowplugger
Here's a pic of the offending area on the driver's side. WHatcha think?
Old 10-04-2016, 12:57 PM
79jasper's Avatar
79jasper
79jasper is offline
That's the tie rod.
Old 10-04-2016, 04:48 PM
Crims's Avatar
Crims
Crims is offline
x2 on tie rod end. I changed just about every part in the first picture posted when i got my truck because they just wear with age and miles. It's easy enough to change just make sure you take measurements (with a tape or count threads or something) otherwise your alignment will be off and you'll wear a tire out pretty fast. Not that I had to do that or anything.....
Old 10-04-2016, 05:26 PM
Glowplugger
So I just need a new tie rod and it'll fix that? I was thinking I could get away with just tightening that castle nut and walking off
If that's all I need, can I pick this up and I'm good to go?
http://www.ebay.com/itm/Steering-Tie...ZXP3wm&vxp=mtr
Old 10-04-2016, 05:41 PM
Crims's Avatar
Crims
Crims is offline
i'm a big rockauto fanboy. that's where i ordered my parts when i replaced mine. like i said the big thing when replacing the tie rod is not messing up your alignment.
Old 10-04-2016, 05:52 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
If 1 is worn the others are not far behind or also worn out.
I've never heard of Verto brand parts so I can't comment on them but I'd tend to choose parts of known quality for my steering components
Old 10-04-2016, 05:59 PM
Glowplugger
Can't fight with that! So Ford brand here would be OK?
New Ford Tie Rod End RH 3C3Z 3304 CA F 250 F 350 Super Duty rwd 1999 2007 | eBay
There are only two, right? Left hand and right hand? Looks like the duo will cost me about $100 all said and done.
Old 10-04-2016, 06:12 PM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
Since it has a grease fitting, that one has already been replaced once but not greased since by the looks of it.
PLEASE do not drive it until you get it replaced. It looks like it is about to fall apart.
Quick Reply: Tire wiggles
