6.4L Transmission Filter Upgrade on a 6.0L
#61
I just did this upgrade yesterday, having read this thread I used my vise as mentioned and popped the case open to get a look at the filter, looked about the same as the one in your video. I suspect the filter was never changed and my truck has 189,000 miles on it. Thanks for putting the video together, I love these forums for things like this and the conversation it creates.
Dan
Dan
#62
Scott
#63
#64
Yes, that's what I heard.
#65
#66
#67
Did the old pump have cold temp problems with the original design filter. That then would make it an issue no matter the filter.
#68
#69
#70
#72
great video jack... little late for this comment... but one thing i would point out a bit missed in the video is that the filter sits down in that recess.. which the filter would displace some of that fluid sitting there... so it wouldnt be a full qt sitting in the base of the pan... would probably be more along the lines of 1/2 qt because of all the plastic surrounding the filter.. but empty without the filter, yeah it take a full qt..
that said i would like to someday see the 6.4 pan filter cut apart after use like you did with yours.. to see what all it catches... for me the video just confirms theres no real NEED to convert to the newer filter since the original design is doing its job...
I know mark said it wasnt a concern to him on your trans fluid temps taking so long to warm up to 160... but my trannys usually up to temp by time ive gotten 10 minutes down the road..
#73
hey jack can you do me a favor... can you measure the dimensions of the old pan and compare it to the new pan you just put on... friend on another boards being told the newer pan wont fit because its larger over all than the old style... but i thought the only space that really changed was the point where the filter sat, so it shouldnt effect his truck...
hes being told there would a clearance issue with the exhaust... i think those people are more referring to the aftermarket non-ford pans which are nothing but a big square box of aluminum... but hes taking it to mean the factory updated pan...
#74
#75
