Never been so happy to have such a worn out gift
This thing's front brakes drink almost as much brake fluid as the engine drinks gas!
I've lost a bottle and a half of brake fluid through the fronts in about 200 miles. Pretty sketchy.
I also learned that either the headlight switch or dimmer switch is questionable. One night last week the low beams weren't working and suddenly they did again after playing with switches.
I tore the headliner out because I didn't like it sagging on my head and the old staple job wasn't working anymore. That roof sheet steel is so pretty and NOT rusty!
Be VERY careful about those brakes. Even an ounce of brake fluid loss can turn into a complete failure at the wrong time (not that there's really a "right" time for brake failure).
Both the headlight switch and floor beam switch are common failure points on these trucks. Headlight switch carries the full current of the headlights and is under-engineered for it. The "faincy" fix is a relay harness, that offloads the main current load so the switch only carries the load to fire the relays. The floor beam switch is in a perfect place to get rusty/nasty.
That's an awesome shot of it parked in town, next to the ugly new drab silver Chebby and Yota. Show 'em what a _truck_ looks like....
And +100000 ^^^^^ re. the exhaust fumes. It's the part you can't smell (the carbon monoxide) that can kill you. Run a straight pipe all the way back for the time being.
I think those explorer stripes are sharp too. This was a pretty pickup back in its day. I may make a clone someday.
I drove it to work yesterday before I made my comment about the brakes. Later I went out to see if it had any obvious leak. There was brake fluid literally dripping out of the line near the right rear wheel. I pinched the line with a hammer to try to slow the leaking and took gravel roads to my parent's place and switched back to my old skunk for the rest of the trip to my house. I learned that Rusty pickup is easy to downshift without the clutch (who knows when that will go away too!). I only had to use the brakes about 4 times in the 15 mile trip.
The line that is total junk is only about 20" long so I may find a replacement. We'll see.
Well a rear brake leak/failure is a LOT less risky than a front, at least.
Just noticed, for as rough as the seat, door panels, dash top, etc. are, the fake woodgrain bits look surprisingly fresh. My '85 has the "burl" wood over dark red, and by now, it looks like barfed-up beet soup. Weird how the decades ravage some things, spare others.....
It's also interesting to look for wear marks from the human touch. For instance, rubbed off paint at the base of the window on the inside and outside of the door.
I was talking to one of my uncles about that type of thing. He collects Allis-Chalmers tractors and always looks for wear marks. One of the tractors had a funny wear pattern on top of the fender. He figured out that it was from the guy's hand rubbing it when he turned in the seat to look behind him. He said he loves finding those bits of character and tries to retain them in any restoration since they are such a human part of their existence.
#29
