Window weather seal
I assume you are referring to the window felts ? If so, I removed all the clips, and glued them in with 3M black adhesive silicone. I cut some small wooden wedges to hold them in place & dry overnight, I only did one felt strip at a time. They are tight secure, it worked out well.
I can't seen to find any pictures for you.
Indeed the china made POS clips DO NOT work . The dia. is too small to fit & stay in the holes . Clean up the old original clips , mark the felts with a white chalk where they go , insert clip , crimp on w/ flanging pliers . It works . This was the process done on both trucks .I have some extra original clips if you need some . Later , Denny
I recently rebuilt my doors, including the installation of new felt anit-rattle pieces. I had little difficulty installing them, but I did unattach the window regulator and dropped the glass enough so I could get my fingers in and apply pressure to the buttons to get them to snap in. I also applied a bit of Vaseline to the buttons. It seemed to help.
I looked at the MidFifty catalog today. Their tip is to glue them on!
Does anyone sell the felt with stainless the bead that poprivets to the division bar? MidFifty only sells the deluxe cab or Custom Cab division bar with the stainless finish. The division bars for the standard cabs was painted black. So I want to use my division bars after I repaint them so I just need the felt with the stainless bead. This is for my 55F350.
Is this what you are looking for? No vendor touches Steele for quality.
Steele Rubber Products - Flexible run channel
Regards, Mark.
Regards, Mark.
The only problem I had with my lower felts was in the rear corners. It appeared the metal in that area had been bent away and needed some realignment before installing. To get the clips to pop into place I dropped the glass into the door, held the felt in place then used a fat chisel which, when pushed down, would press the clip into its hole fairly easily.
MontanaboyDesigns
08-15-2016 10:05 AM
dthut
02-23-2016 11:45 AM
yankeerebel
05-02-2010 03:51 PM
