Hey All, I recently replaced the power steering pump and both lines but I just can't seem to get the air out of the system. Anyone else had this issue? Maybe a solution?
normally you crank the wheel all the way to the left till the pump runs over relief and hold for 2 seconds, then run all the way to the right till the pump runs over relief and hold for 2 seconds, then back left... etc... normally 3-4 cycles will get all the air out... check tank level after 2 cycles and make sure you are still full.
I just replaced my power steering hoses and lines. I had no problem getting the air out. Maybe air is being sucked in by a bad pump seal? Just a guess.
Air must be being sucked in somewhere on the pump. Let it sit and then look for signs of weeping. Try removing the reservoir cap and see if you can pressurize it - inspect pump for weeping.
