Help creating users gallery
When we say the instruction s are in the user gallery forum.
That means you should look for a thread(s) that have asked the same question so we don't have to answer 100 times, we just answer 5-6 times.
here is another thread 5 Thread below this one.
https://www.ford-trucks.com/forums/s...hreadid=125103
6 threads below this one is a thread titled Avatar
Maybe look in there and see what it says.
If you are still having problems with it get back to me.
Also there are more pages this this one,
Set the default to *Since the beginning* instead of the *last 30 days*
Good luck !
Good luck !
Okay, I found the "user cp" function and went to "edit album" and then "create album" and did alot of typing and still saw no place to ad pictures and then when I clicked on "create album" at the bottom nothing happened. I went back to look at the user gallery and there was no information on it???????
What am I doing wrong?
Good luck !
Good luck !
Go to the photo you want to use>
Click
Forum codes
2 codes will appear
Highlight the bottom code (it says thumbnail)
Once it is highlighted > with cursor in the text box
Right click mouse
Then
Left click COPY
Now leave the area & go to your setting page
Scroll down until you see " Add or Change Avatar
Once there you will see http//:
Delete that part
Now in that same area put cursor in that box and left click mouse
Once the cursor is flashing in it
right click mouse
Now left click the word PASTE
Text will appear
Click save (update profile or something like that)
You're done
Click
Forum codes
2 codes will appear
Right click mouse
Then
Left click COPY
Delete that part
right click mouse
Text will appear
You're done
