1966 F100 seat foam - Page 3 - Ford Truck Enthusiasts Forums
1966 F100 seat foam
Old 12-10-2017, 09:37 AM
66with352's Avatar
66with352
66with352 is online now
66with352 is starting off with a positive reputation.
Seems like the consensus is custom cab seat bottom cushion is 5" thick. The "guess" for standard is 1-2" thick,. Does anyone have a more definitive for the standard cab seat bottom thickness? Probably finally get to mine this winter.
  #32
Old 12-10-2017, 09:52 AM
swoosh1958's Avatar
swoosh1958
swoosh1958 is offline
swoosh1958 is starting off with a positive reputation.
Post #11, I talked to MN66, he said for the backrest 1" foam and 1" poly covering the entire foam. He said it was tight and would not recommend 2" foam and poly. My backrest foam is 1 3/4" thick. I guess it depends on the cover also, not all upholstery will be the same. My 1966 CC has a full 5" of foam on the seat cushion.
  #33
Old 12-10-2017, 10:02 AM
swoosh1958's Avatar
swoosh1958
The email says:
"For the seat back, I'm not sure there would be room for 2" of foam, mine feels pretty taught with 1" foam plus batting. Maybe if you shaped the top edge and sides? I left my edges square and overlapped the Polyester batting just slightly over the foam and seat frame. On my seat bottom, I first used some heavy vinyl upholstery hog-ringed to the seat frame over the top of the springs. Then I spray contact adhesive on the vinyl and first layer of foam. Then added the second layer of foam with adhesive, followed by the polyester batting on the seat surface and down just beyond the frame. When I installed the seat cover, I tucked the polyester batting into the seat cover so it can't be seen underneath the seat."
  #34
Old 12-10-2017, 11:12 AM
66with352's Avatar
66with352
Wow, my bad, I thought he was referring to CC. That's what happens when you try to read and do other things at same time.
  #35
Old 12-11-2017, 08:28 AM
Dakota Boy
Dakota Boy is offline
Dakota Boy is starting off with a positive reputation.
see attached file. slightly less than 2" for the seat back, and 5 inches for the bottom seat cushion.
  #36
Old 01-24-2018, 04:28 PM
swoosh1958's Avatar
swoosh1958
swoosh1958
17
01-07-2018 07:30 PM
terry274
08-26-2017 11:33 AM
1970f100guy
04-23-2017 06:31 AM
maine71f100
04-21-2017 12:23 PM
Russ74
02-07-2017 08:28 AM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
