1966 F100 seat foam - Page 2 - Ford Truck Enthusiasts Forums
1966 F100 seat foam
Old 02-28-2017, 08:42 PM
MN66 MN66 is offline
MN66 is starting off with a positive reputation.
I had quotes of $850 and $1100 to have the work done. To me that was stupid money.
I spent about $250 on materials and it took me about 8-10 hours to strip it down to raw metal, paint it and reupholster.
It was my first time doing anything like it, and it was kinda fun. It's better to have 2 sets of strong hands when you get to the last half of the hog ringing. Best to do the work when the vinyl is warm and pliable.
Regards,
Corey
Old 03-01-2017, 05:51 PM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Yeah I agree that's a little spendy for what it is. A good bench seat is pretty comfortable, like driving the couch. $250 sounds OK have to look into this.
Old 03-01-2017, 08:03 PM
swoosh1958's Avatar
swoosh1958 swoosh1958 is offline
swoosh1958 is starting off with a positive reputation.
SEATS
Your seats look great!
Old 03-01-2017, 09:07 PM
Tedster9's Avatar
Quote:
Originally Posted by 66with352 View Post
The tags are still on the back and bottom springs. Not sure what that tells me..... if anything.
The truck build sheet is there, under the springs too. That will tell you a whole lot more.
Old 03-02-2017, 12:05 PM
James_Western_Canada James_Western_Canada is offline
James_Western_Canada is gaining momentum as a positive member of FTE.
Tedster: There are covers available with the gear & lightning bolt from both SMS in OR, and Distinctive in CA
James
QUOTE=Tedster9;16986650]Do upholstery shops rebuild these seats and recover them for at least, not stupid money? The reproduction vinyl covers are a little spendy, and they don't even have the gear and lightning bolt afaik.[/QUOTE]
Old 03-02-2017, 12:13 PM
Tedster9's Avatar
Quote:
Originally Posted by James_Western_Canada View Post
Tedster: There are covers available with the gear & lightning bolt from both SMS in OR, and Distinctive in CA James
Thanks! Good to know.
Old 03-02-2017, 07:54 PM
swoosh1958's Avatar
SMS says $695.00 for a seat cover. Any color. It is vinyl and cloth (plastic type feel)—like the original. Says Doug at SMS.
What do you think of this cover? I heard that the covers with the cloth tend to pull the strings out. But I don't know. Seems kinda pricey.
The logo is really nice though.
Does this seat cover/set look like a Custom Cab ?
Old 12-07-2017, 03:37 PM
swoosh1958's Avatar
Thanks Corey, for the tips!
Old 12-07-2017, 03:55 PM
zackcj7's Avatar
zackcj7 zackcj7 is offline
zackcj7 is gaining momentum as a positive member of FTE.zackcj7 is gaining momentum as a positive member of FTE.
The back looks pretty close to what's left of my factory custom cab seat. But the vinyl weave is not on the bottom on mine.
Old 12-07-2017, 04:03 PM
swoosh1958's Avatar
My original is smoke! Lol.
Old 12-07-2017, 04:54 PM
TA455HO's Avatar
TA455HO TA455HO is offline
TA455HO has a good reputation on FTE.TA455HO has a good reputation on FTE.
My one 4x4 truck still has its original seat covering in good shape. One small tear in the center - probably from some object that poked through it years ago.
This is 1966 Custom Cab trim code E81.
Here's a good shot of the grain
And the logo
A bit dusty in this pic, but I cleaned it off since.
Let me know if you want any other pics.
The reproduction cover looks very good. Only thing I've noticed is the seat material - the pattern on the part that you sit on - doesn't wrap as far around the edges as the originals did.
You might think my foam is crushed down or something else is amiss, but that's the way they originally did them. Compare to this shot from the brochure.
Chad
Old 12-07-2017, 09:37 PM
6t6merc 6t6merc is offline
6t6merc is gaining momentum as a positive member of FTE.6t6merc is gaining momentum as a positive member of FTE.
Looks good, Chad. I hope you can find a pro who can fix that.
SMS is the only source and if you don't like their price, you can make some yourself. It is genuine NOS, but expensive.
Eric
  #28
Old 12-09-2017, 07:12 PM
swoosh1958's Avatar
1965 and 1966 seat frame and spring difference.
1966 backrest spring attachment.
1965 backrest spring attachment. It has clips that are welded to the frame.
  #29
Old 12-09-2017, 07:20 PM
swoosh1958's Avatar
1965 and 1966 seat frame difference
Where the backrest attaches to the seat frame is wider on the 1965 also.
1965(56 1/4") 1966 (55 1/2")
  #30
Old 12-10-2017, 10:14 AM
Dakota Boy Dakota Boy is offline
Dakota Boy is starting off with a positive reputation.
bottom foam is 5" . I found a brochure image on eBay for the '66 custom cabs, and that is what the Ford literature said.
1966 Custom Cab Seat Foam swoosh1958 1961 - 1966 F-100 & Larger F-Series Trucks 3 12-10-2017 10:58 AM
1970 bench seat foam 1970f100guy 1967 - 1972 F-100 & Larger F-Series Trucks 11 04-23-2017 07:31 AM
Seat Foam maine71f100 1967 - 1972 F-100 & Larger F-Series Trucks 10 04-21-2017 01:23 PM
Covering seat Russ74 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-07-2017 09:28 AM
F-250 Seat Foam Leew222 1999 to 2016 Super Duty 2 01-04-2016 03:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
