New Dana axles
There is very little out there on the net about them. They are entirely new but the odd thing is they came out a few years back, have not been implemented anywhere that I can see until now, and their key advertising point based on the one info release I found is improved fuel mileage. This is due to the way the gears mesh and the size of the mating surfaces. Nothing in the press release I found mention increased strength but maybe that's supposed to be implied.
The SRW F350 uses the Dana M275 with an axle diameter of 1.47"
The DRW F350 uses a Dana M300 with an axle diameter of 1.47"
The DRW 450 uses a Dana M300 with an axle diameter of 1.85.
These axles are heavier duty overall and use fewer moving parts and are more fuel efficient than the previous Sterling Axles.
Wondering if this is it:
Spicer AdvanTEK High-Efficiency Axles | Dana Light Vehicle
AdvanTEK® Gearing
A Full Range of Quiet, Lightweight, and Reliable Drive Axles for
Light- and Light-Commercial Vehicle Applications
Pinion features to enhance reliability:
Larger diameter pinion stem
Narrow pinion bearing spread
Two-stage pinion preload setting
Pinion mate spherical torus shape
Pinion features that reduce vibration:
Pinion built to position rather than pattern
Major diameter pinion spline fit
Reduced pinion nut backface runout
Gearing features to improve durability:
Wider drive gear face
Differential gear tooth combination
Large diameter flange side differential bearing
Gearing features that maximize efficiency:
Fuel efficient taper roller bearing
Smaller button side differential bearing
Thrust washer features for a quieter ride:
Dynamic backlash measurement
Belleville side gear thrust washers
Thrust washer lubrication holes
AdvanTEK® Gearing
17 Oaks's link has a picture of something that looks exactly what I saw in a recent video of under the truck footage (guy drove over the camera.) The driveshaft was turning and connected to that exact thing in the back. So he may be on to something. Same shape, same fins. The video was posted here but I don't remember which one.
So it has a slightly larger ring gear diameter by about .3" and a smaller axle shaft diameter that the 10.5 Sterling which is 1.5"? I wonder what the tube diameter and thickness is?
It has larger axle shafts than the 10.5. The 275 shafts are 36 splined, 1.43 Minor spline diameter and 1.54 major. The Sterling has 35 splines and is 1.36 minor and 1.50 major. The 10.5 has 3.5 inch tubes while the 275 has 4 inch tubes. Sterling holds 7 quarts of lube while the Dana holds 7.2
I've been trying to track down some info on the Dana M275 which will apparently come under the rear of a '17 F350 4x4 CC KR I'm configuring for order soon... Do you know if/when 4.10's will be available for this axle and if/when ARB will offer an Air Locker for it by any chance...? I can't find any info on this axle on the Dana nor ARB websites...
https://www.dynatrac.com
I know the owner Jim, he mods Ford Dana's and does a lot of custom work for Ford and Chrysler, they know more about Dana than Dana does...Most likely its a bit early for any announcements as it takes a while to build the new gear and before that happens there has to be at least a perceived sales opportunity.
I'd bet money Dana has made 4.10's for it at some point during development. It's been out for a couple years and Dana has surely been shopping it to manufacturers. 4.10 is too commonly used not to have made one. Wouldn't hold my breath on the ARB anytime soon since an electronic locker is already available for 3.33 and 3.55. Don't know where the carrier break is but I bet they made one for 4.10 too.
