Why 3.55 Gearing on the 2017????
As TQ ratings continue to increase, steeper gearsets become less necessary. As stated above, 3.31 and 3.55 have been the only two SRW 6.7 options since it's inception in 2011. Now that the TQ has risen again for 2017, even the DRW 350's are coming with 3.55's instead of 3.73's with 4.10 as an option as opposed to the previous 4.30 option.
The 3.55 is nearly the perfect gear for the 34" tires on that truck. You will run right at peak HP at 70 MPH in 4th gear. With a 3.73, you hit peak HP around 65 MPH. Not a really big difference, but I prefer to have maximum hill climbing power at 70. Shifting to 5th gear WOT right at 65 is not good in my book. It drops you down to 2100 RPM, which is way less power... slow down, shift back to 4th, speed up, shift - slow down...
On a related note, the F450 hits peak HP at 72 MPH in 5th - also a great gear combo.
F350 DRW 3.55 peak HP = 65 MPH - shifts to 5th WOT at 65 - suboptimal for me
F350 DRW 4.10 peak HP = 75 MPH - way better than the 3.55 DRW for me, but not as good as the 4.30
I believe the 3.55/3.31 ratios predate the 6.7 and started off sometime during the 6.4. 3.55 was also an available ratio on the original 7.3's.
The 6 speed transmissions have lower first gears than previous transmissions. You've got a lower starting ratio even with higher axle gears. You can lock out sixth/double over or fifth/single over to get your rpm's where you need them at cruising speed while towing. The higher axle gears get you to a better empty cruising rpm for mileage.
The only thing lower axle gears would accomplish would be to get you into higher rpm's at highway speeds. That could give you all six gears to tow with and keep your splits closer, but I have a hard time seeing that as worthwhile overall for most people.
Cowgirl714
6.7L Power Stroke Diesel
03-27-2017 12:40 PM
