Which fuel pressure regulator?
Old 09-18-2016, 09:53 PM
hail destroyer
hail destroyer is offline
hail destroyer is gaining momentum as a positive member of FTE.hail destroyer is gaining momentum as a positive member of FTE.
Just received my FP reg from summit. NO RETURN LINE! Can I use this?
1978 F-250 351M edelbrock intake and thunder AVS carb. Stock fuel pump.
Thanks!
Old 09-18-2016, 10:12 PM
84espy
84espy is offline
84espy has a great reputation on FTE.84espy has a great reputation on FTE.84espy has a great reputation on FTE.84espy has a great reputation on FTE.
Did you have a return line to begin with? If not, then you shouldn't need a return line for this unit. A pressure regulator usually has a max pressure rating on the inlet side. If your fuel pump pressure is lower than this max rating, then the regulator will handle it. Think of that water spray nozzle on the end of your water hose at home. Holds full pressure when you turn on the water and you can regulate the pressure or flow by opening as much as you wish. No need for a return line. On a side note, I suggest using the Edelbrock low PSI fuel pump. Works great with my Holly.
Old 09-19-2016, 10:55 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
If you have a stock fuel pump, you don't need a regulator. Unless you have one of those big Holley mechanical pumps, I wouldn't consider a regulator, and even the aftermarket pumps are designed with max carb psi in mind.
Old 09-20-2016, 09:59 PM
PapaBearYuma's Avatar
PapaBearYuma
PapaBearYuma is offline
PapaBearYuma has a good reputation on FTE.PapaBearYuma has a good reputation on FTE.
I installed the Summit regulator in the yellow truck. I put a plug in the second outlet. No need for a return line. Truck and carb are very happy
Old 09-21-2016, 09:10 AM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
ZarK-eh is gaining momentum as a positive member of FTE.
That looks like a Holley 12-803BP Bypass (Return line type) Regulator!
I used one with the stock carb and EFI pump and tanks.
Oh wait, the case is different, mine says "IN" "OUT" and "RET". And the photo doesn't have a Holley brand on it... Although it looks very similar.
What ever works to not blow fuel past the needle and seat!
2duff2
11-07-2016 11:40 PM
timpage
27
08-10-2016 10:53 PM
eutecticpt
06-29-2016 10:01 PM
jspringator
05-17-2016 09:24 PM
big315
05-13-2016 01:08 PM
Quick Reply: Which fuel pressure regulator?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
