2005 3valve one cam position sensor or two.. ecm or pcm VK2-C3592
OK so i know its got to be here but im freakin blind or ... anyway i have a 2005 f350 6.8l v10 that has been cut all to pieces and im trying to add a aftermarket radio and no dashlites...which is another story but im looking for the pinout on the pcm VK2-C3592 5c3a-12a650-mca JUV0..i have one sensor hooked up on the passide and it has a white with red and a blue with orange going to it.. the one on the driverside is Not hooked up and i pulled the wiring loom apart and no sign of any connector or spliced or cut wires anywhere close to the cam pos sensor so...was gona run from the pcm to sensor...
thanks
thanks
no sir its up right outside cam spkt cover slightly off from the one on driverside i will get pics.. think im bout the pull the char canister off and gut it?? tired of having to make an additional 20-30 just for Gas..pushwater whatever .. u wana call it.. dropped tank and the evap lines were half full of mud dirrt etc ..
deezdrama
07-01-2016 12:38 PM
