Lookie this lowering job..SMH
Old 09-17-2016, 04:19 PM
Kurt G.'s Avatar
Kurt G.
Kurt G. is offline
Kurt G. is gaining momentum as a positive member of FTE.Kurt G. is gaining momentum as a positive member of FTE.
I was looking at ways to lower a solid axle Ford and look what I found. What you think???
Old 09-17-2016, 11:32 PM
Kurt G.'s Avatar
Kurt G.
Kurt G. is offline
Does this look like something that could be called safe? I see the gap between the bottom of the axle and the plate, I would also be concered about the strength of the square tubing. Does anybody have an opinion on this. I want to find an affordable way to lower mine and this looks like it might work.
Old 09-18-2016, 06:00 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
That would definately lower your ride. You picture doesn't look like F100 springs. It looks pretty stout but the gap puzzles me too. Not sure how that much of a drop would effect your steering geometry.
Old 09-18-2016, 08:00 AM
TireDood's Avatar
TireDood
TireDood is offline
TireDood has a good reputation on FTE.TireDood has a good reputation on FTE.
that caster wedge is completely useless.... that does not look safe at all to me!
Old 09-18-2016, 08:13 AM
bjmayberry2
Yep it would need to be between the spring & axle to be of any use.
Old 09-18-2016, 11:06 AM
Moe Craig's Avatar
Moe Craig
Moe Craig is online now
Moe Craig is a name known to allMoe Craig is a name known to allMoe Craig is a name known to allMoe Craig is a name known to allMoe Craig is a name known to allMoe Craig is a name known to all
I agree with others about the channel, adding bolt casing (steel pipe) for the bolts, a couple of support between the bolts and capping the ends would help stiffen the channel to make it stiffer. I would also like to see a top plates welded onto the top of the Channel (bracket) to support the whole axle plate, instead of relying on the bolts to keep the axle from rolling.
Caster Wedge... LOL... I've always said if you don't have anything nice to say, Say nothing.... Hehehe...
Old 09-18-2016, 11:29 AM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Diesel Junky
mechmagcn is a name known to allmechmagcn is a name known to allmechmagcn is a name known to allmechmagcn is a name known to allmechmagcn is a name known to allmechmagcn is a name known to all
If I were to build something like this I would probably go as far as making it out of solid blocks instead of tubing, but that said, if they would have at least capped the ends it would strengthen that piece quite a bit.
Old 09-18-2016, 11:47 AM
Kurt G.'s Avatar
Kurt G.
Kurt G. is offline
Yeah I know I was trying to figure out the caster wedge as well. This they stated was off a Ford Van. That caster wedge looks like it would make the shackle bolt hit ground if it had full blown tire off rim. I may look for more on this, yes steering geometry would be off, dropped tierod end, and not sure about steering box location.
Old 09-18-2016, 11:53 AM
Kurt G.'s Avatar
Kurt G.
Kurt G. is offline
Scndsin
21
02-27-2019 01:22 PM
Rezza56
07-09-2018 10:20 PM
mzwizanski
12-31-2017 06:44 AM
F151
13
06-04-2017 07:58 AM
74dailydriver
1999 to 2016 Super Duty
11-20-2016 08:11 PM
Quick Reply: Lookie this lowering job..SMH
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
