Dang! lost serpentine belt and overheated
I was cruising along yesterday and felt the steering pump go out on the highway. Nowhere to pull over and pulling a big horse trailer. Three miles later I finally get to a wide spot to dive into. I look down and the temp gauge is maxed and the oil light is on. Most of the antifreeze boils out when I got the engine shut down. I had no choice but to have a friend bring a new belt and some antifreeze to the rescue. Got it changed and filled back up. Started and drove home fine.
I've got this twisted gut feeling about the whole deal. What kind of damage did I likely do? Things to look for? Did I just kill the longevity of the motor? I've been trying to do things right and treat it well to ensure a reliable truck.
On a side note the belt came apart in ribbons and it was absolutely shredded. The belt appeared to be less than 3 months old. No cracks or tears and a bright white numbers sticker on the back
Received 3,697 Likes
on
I bought an aftermarket tensioner and while trying to remove the belt one day for some work on the AC compressor the prying position on the tensioner sheared clean off... I say try to get a good one if replacing.... When it comes time I'll have to probably cut the belt and replace the tensioner at the same time.
If I were you, I would look closely for the cause of the belt breaking like a loose or out of alignment pulley. Replace the tensioner and belt if the one you have now is not new. Then, flush and replace coolant and oil. Then, monitor things for a short while and you should be good to go if there is no mixing of fluids or abnormal symptoms. These engines can take a lot of abuse and laugh at you when you are worried about it.
Kelpy1, pause for just a moment here.
Do not mix ELC with regular coolant. Do not use spring water.
Use regular coolant OR ELC. Use only distilled or deionized water.
Have fun on your trip, keep the water (see above) close by in case you need it to refill the degas bottle. Once you return home, flush the system and replace the oil.
If that's the case, I can fully understand him wanting to do a full flush now before he heads out on a trip.
If I am wrong then all the above does indeed apply.
