How do you get the door chime to go away when the key is still in the ignition?
Also, how do stop the driver seat from moving every time the key is removed?
Thanks
That chime is the worst. I can't believe Ford doesn't have a simple off button for it. There are some threads about it. I put tape over the speaker behind the cluster. Someone more recently has figured out how to disable it in the key tumbler, which looked pretty easy. I will look for the thread.
Thanks for the link. I looks pretty simple. The only concern I have is if the 2016 and 2005 are the same. I will see what it looks like later today.
Thanks.
How do you search this site for these posts?
I'm pretty sure I've seen it done on the 11-16's. There is a search tab in each forum section. I have also used google. Google "door chime ford truck enthusiasts" or similar search words.
Thanks for tips.
Any idea on how to get the seat to stop moving when you remove the key?
I think there is a setting you can turn off in the menu that is called "easy exit" or something to that effect. It is designed to have the seat go back to supposedly make it easier to get in and out of.
