2003 F-250 V10 P0171 only.
I just had the fuel pump replaced and fuel filter. Picked the truck up left right when it got to about 2500-3000rpm it started hesitating... then put my foot to the floor itll kick down and just detonate and miss wont go anywhere... if i am accelerating i have to keep it under 3/4 throttle and 2500-3000rpm to get up to speed. I have now replaced the plugs, fuel pump fuel filter and MAF. i dont see any rips or tears in the pcv hose, the pcv also still rattles when i shake it... im stumped.... really need to figure this out thanks
I'd continue to look, hear, or just find a vacuum leak. Most likely why it is pulling that code.
Good luck.
yeah its different on an 03 they changed it. i pulled my injectors today cleaned all of them, took my coils off and cleaned them all up including the boots, ohm tested all the coils im stumped... all i can think now is the pump i bought is bad.... but the shop said they ran it on their analyzer and is said all fuel pressures were good... so im stumped...lol
firstonraceday
16
06-09-2011 06:59 AM
