Dana 50 ball joint torque
This picture has some torque numbers in it.
Here's some other numbers;
Install the splash shield and spindle on the knuckle. Tighten the spindle nuts to 60 ft. lbs.
Ball-joints:Tighten the bottom nut to 80 ft.lb.
Tighten the top nut to 100 ft.lb., then, (tighten) advance the nut until the cotter pin hole align with the castellations. Install a new cotter pin.
Again tighten the bottom nut, this time to 110 ft.lb.
hail destroyer
10-31-2017 06:46 PM
maxride
03-07-2015 07:25 PM
