9in gears
Old Sep 14, 2016 | 12:25 AM
Shadowrider123's Avatar
Shadowrider123
9in gears
Im shopping for a better set of gears for my 64 F100.
The tag says 3.10. ND says thats not possible, but thats what it says.
My speedo is off 17mph. Indicated speed 50mph, actual speed 67mph.
To much to correct with a driven gear change, current gear is 17 teeth..
I suspect the truck had a much steeper gear when new. Its a 292/AT.
I want a 28 spline 3.25 or 3.50 gear. Other than F100/F150s what other vehicles should I look at?
Im tempted to look for an Explorer 8.8, the 9in is overkill for my truck. Its low hp and its not going to do any work as long as I own it.
Old Sep 14, 2016 | 04:30 AM
jowilker's Avatar
jowilker
I see different opinions on testing for ratios, raise one wheel, raise both wheels, but I like something a little different, roll the truck on the ground. 1st get a bud for safety and with the truck on a very level ground (like a garage floor) mark the left rear tire, roll it one complete rotation while counting the rotations of the driveshaft. You can mark it with a Sharpie, piece of tape, you choose.
This will give you the actual count with no possible interruptions. You will need at least 2 teeth different on the speedo gear to get a closer reading.
John
Old Sep 14, 2016 | 04:36 AM
Crop Duster's Avatar
Crop Duster
Try car-part.com and set the search for distance. You will get back more results using carrier in the search box. Any 28 spline will work. And they are about as common as rocks. I would try to find one that has the correct yoke on it though. I believe Ford used something like 7 different yokes over the years. Changing the yoke isn't a big deal but there is a little more to it than just swapping them out. I would stay away from the 8.8 unless you are into re-engineering the whole backend of your truck. Or you could just have yours rebuilt, that way you get new everything in the ratio you want.
Old Sep 14, 2016 | 05:24 AM
matthewq4b's Avatar
matthewq4b
Any just about any 1960's or 1970's full or mid size car (minus the Granada and Comet). So you are looking for stuff like T birds, Cougars, LTD's, Galaxies Torino's, Mustangs (pre 74), Lincoln's, Mercury Marquis's and Montego's Colony Park wagons, Cougars. You only need the Crown and pinion so axel spline count is not a consideration unless of course you are looking to swap the whole pumpkin. If I remember correctly some of the larger cars and trucks have a 9 3/8" Ring gear. You can identify the 9 3/8" case by the curved top support rib on the case See the Below pic borrowed of the internet. The 9" case rib goes straight across.
The 9 3/8" pumpkin will fit the 9" housing if you cut the clearance notch in it for the larger gear like the 9 3/8" housings have
Once you pull your pumpkin you will know exactly what your gear ratio is as it is stamped on the ring gear. The you can then calculate how high you can go with the driven gears available. Remember the 9" was available with some really high ratios around 2.3:1 I think the ratio your truck had stock was around the 3.89 mark.
Old Sep 14, 2016 | 07:10 AM
ultraranger's Avatar
ultraranger
In the bumpside trucks ('67-'72), the axle code on the warranty tag affixed to the drivers door with a code of "08" would be a 28-spline, open differential with 3.50 gears. A "17" would have 3.25 gears and an "09" would have 3.70 gears. Some '68-'72 Ford F100s came with a Ford 9-3/8" rear end. All of these had 31-spline axles/differentials.
All Bumpside trucks with a Ford 9-inch rear end had a 28-spline differential/28-spline axles. Many of the Dentside ('73-'79) trucks had 31-spline differentials/axles but there were some with 28-splines. All Bullnose ('80-'86) trucks with a 9-inch rear had 31-spline differentials/axles.
Ford passenger cars with a 9-inch rear end generally have longer companion flanges (where the driveshaft attaches to the 3rd member) than the companion flanges on the trucks.
Old Sep 14, 2016 | 10:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by matthewq4b
Any just about any 1960's or 1970's full or mid size car (minus the Granada and Comet ).
1975/80 Granada/Monarch could have 8" or 9" or the WER integral 8.7" rear axle.
1976/80 Granada/Monarch 9" came with rear disc brakes. This same rear axle with discs used in 1977/80 Lincoln Versailles ("rebadged" Granada).
The 8" was introduced in 1962 Fairlane/Meteor, it looks very similar to the 9."
1966/69 Comet could have an 7 1/4" integral, 8" or 9" rear axle.
Old Sep 14, 2016 | 10:38 AM
ID Scrounger's Avatar
ID Scrounger
Do you want a different gear seat or just a correct speedo reading? If it's just the speedo then there is a much easier means to that end: http://www.ebay.com/itm/like/131689402154?lpid=82&chn=ps&ul_noapp=true
Old Sep 14, 2016 | 11:30 AM
matthewq4b's Avatar
matthewq4b
Thanks ND I knew they did come with a 9" as did the Versailles but they are not common and usually are gone PDQ with the rear disks.
I think most came with pretty high geared rear ends also. So I just omitted them. Even finding something as steep as 3.5'ish in a car is a tough go unless it is a stang.
Old Sep 14, 2016 | 11:34 AM
ultraranger
Yep. I have a Monarch 9-inch drum brake rear end as well as a Versailles 9-inch disc brake rear end.
Old Sep 14, 2016 | 04:40 PM
Shadowrider123
I may rethink the rear swap. 3.10s should be pretty good behind a healthy engine in a F100.
I guessing my 292 is putting somewhere around 100hp to the wheels, maybe less.
With modern head gaskets Im probably at 7.5:1 compression, AT and the crossover single exhaust. Not a good performance package.
Old Sep 15, 2016 | 09:59 PM
frty7ford's Avatar
frty7ford
I swaped in a set of 3.00 into my 65 f100 with a 240 I did not have any problem going down the road. I ended up putting a set of 3.55's in because the 3.00 was too tall with my overdrive. If I dont use the overdrive 3.00's are great
Old Sep 16, 2016 | 07:05 AM
ultraranger
I don't know what overdrive transmission you have but assuming it's 2/3rds overdriven at .68:1, your final drive equivalent with 3.55 gears would actually be even higher than the 3.00:1 gears you had without overdrive.
Final drive equivalent is figured by multiplying the overdrive ratio of the transmission by the gear ratio of the rear end.
.68 x 3.55 = 2.41:1.
In overdrive with 3.55:1 rear end gears, it would be as if the rear end had 2.41:1 gears in it.
With an overdrive and 3.00:1 rear end gears, the final drive equivalent would be 2.04:1.
Old Sep 16, 2016 | 11:34 AM
frty7ford's Avatar
frty7ford
I have the stock 3 speed with the r11.
Your numbers sure make sense and explain why my motor didn't like the 3.00 gears with the overdrive engaged.
UpLateAgain
17
Oct 13, 2012 12:26 PM
Encho
1978 - 1996 Big Bronco
Mar 4, 2008 11:25 AM
PCWest13
Aug 16, 2006 07:52 PM
Dads 66
Apr 12, 2005 09:31 PM
castiron
Oct 6, 2003 03:39 PM
