2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
No 3.73 LS axle in 2017?
Old 09-13-2016, 10:49 PM
MT79's Avatar
MT79
MT79 is offline
I have seen several window stickers that show a limited slip rear axle in a 2017 Expedition (not EL) but the dealer says it is not available to order. Can anyone verify this? I got burned by the Dodge dealer on this same issue when I bought my Ram so I want some corroboration. Thanks.
Old 09-14-2016, 07:26 AM
B-McD's Avatar
B-McD
B-McD is offline
I just did a build on the Ford site for a 2017 Expedition Platinum just like my 2016 and it shows that 3.73 axle as a $320 option. Maybe not available on certain trim levels perhaps??
Old 09-15-2016, 02:46 AM
glockholiday's Avatar
glockholiday
glockholiday is offline
But was it a Limited Slip?
Old 09-15-2016, 06:29 AM
B-McD's Avatar
B-McD
B-McD is offline
Glock - Good call - went back in and pulled the details up in the configurator:
The 3.73 Limited Slip Rear-Axle is standard on all extended length models with the 4x4 drivetrain. It is optional on all other model configurations.
Sounds like MT79's dealer needs to do some more digging.
Old 09-15-2016, 10:21 AM
Beachums's Avatar
Beachums
Beachums is offline
You won't get a limited slip. You will get an open diff only. The traction control system utilizes wheel sensors, engine retard and individual brake actuation to work. Limited slip will not work with that system.
If you can get the 3:73 on the short WB, I would get if you are towing....alot or in a mountainous region....or you drag race it.
I would rock the 3:55 if it is a mall crawler....better gas mileage.
Old 11-19-2016, 07:44 PM
ExcursionPSD's Avatar
ExcursionPSD
ExcursionPSD is offline
On page 1 of the MY16 Expedition RV & Trailer Towing guide, it shows a Rear Axle Ratio Code chart, which lists the 3.73 Rear Axle Ratio as using a Limited Slip unit with AXLE code "3L". My Expedition EL 4x4 has this AXLE code
The 3.73 ratio is standard on the Expedition EL 4x4, and OPTIONAL on EL 4x2 and Expedition short 4x4s.
The MY15 Expedition RV & Trailer Towing guide, shows the 3.73 Rear Axle Ratio as using a NON Limited Slip unit with AXLE code "16".
Last edited by ExcursionPSD; 11-29-2016 at 01:35 AM. Reason: corrected optional 3.73 availability
Old 11-20-2016, 05:25 PM
Beachums's Avatar
Beachums
Beachums is offline
The 3.73 ratio is standard on the Expedition EL, and optional on others.
I wonder how the traction control works if they are using a limited slip. They must have redesigned the system.
Old 12-19-2016, 08:17 AM
jeffkushner's Avatar
jeffkushner
jeffkushner is offline
FWIW:
On the build sheet (FordEtis home page) for my '17 Limited it shows"
Ford Series
Engine: 3.5L V6 GTDI
Transmission: 6 Speed Automatic Trans (6R80)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.73
Then below in the "minor features" section it shows:
3.73
Rear Axle Limited Slip Differential
jeff
Cfrank89
1999 to 2016 Super Duty
11-05-2017 07:51 PM
jschira
02-07-2010 09:02 AM
ron570
03-23-2009 11:30 AM
Tom in Michigan
02-09-2008 12:49 PM
Fuzydog
01-25-2008 06:55 AM
Quick Reply: No 3.73 LS axle in 2017?
