Passenger Fresh Air Vent
I was picking thru a '64 parts truck and brought home the passenger side air vent cable and vent assembly that I'd like to swap on my '62. Mine has an accordion lookin' thing between the air vent and heater box, and a lever that opens a door for air flow in the cab. The '64 didn't have the accordion, and was missing what I suppose was a plate to block the side of the heater box. So I'm wondering if it's a fairly easy swap, assuming I can find or fabricate the missing plate on my heater box. I mean should it be as easy as it looks?
Ok, so swapping my fresh air vent for the '64's recirculating seems to involve mostly changing the air tube things at the kick panel and attaching the vent cable at the dash like I thought. Would it matter if I still kept the accordion attached to the heater box after the swap, or should I close it off? Seems that if the vent were closed it would still think it was a recirculating heater? Is there any advantage to either system? Or am I just nuts?
If you remove the bellows and close off the opening on the heater you won't have any heat in the truck. On my '66 I 've thought about putting a trap door in the bottom of the bellows so that it can work as a recirc heater when the main vent is closed.
Is there a reason you want to switch to a recirc heater?
To be honest, I just want a functioning cable to replace the chrome plug on the dash. I had no idea there are two types of heaters - news to me. I'm not even sure I can get the cable attached to the dash without removing the new glove box I've already installed. Removing the original one was an exercise in total futility. The donor truck's was already removed so I couldn't practice on that. Maybe I'll just leave well enough alone, at least it works. Appreciate pics, ND. Always something to learn here!
C1TZ-8101890-B .. Right & Left Vent Cable-Includes **** / Obsolete
1961/64 F100/1100 / 1963/69 N/NT500/1100 / 1965 F100/250 4WD / 1965/66 F350/1100 / 1966 F250 4WD / 1967/69 F800/1000.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 104 = 800-476-9653.
Conserv
01-17-2014 12:40 PM
youngfordkid
01-29-2012 03:00 PM
BlueDolphin
07-29-2005 01:09 PM
