2004 6.0 no crank no start pcm not reading tuner
All of the sudden my 2004 6.0 Excursion has a no crank no start, I noticed it isnt reading my tuner and or scan gauge. I took it to the diesel shop and he swapped the pcm and it fired up. Switched it back and it pull the fan clutch and sent the pcm into safe mode. Put a new Fan Clutch in fired it up and it all seemed normal. Took it for a test drive and it shut off again, when it shuts off, no fuel pump, no gauges, no tuner, just does nothing. Switched the pcm again and it fired up we test drove it and it seemed ok but still didnt feel rite. Am i headed in the rite direction with maybe a new pcm? Just want to make sure because there like $500.
Please help
Please help
After swapping out the pcm the truck would continue to shut off and pull all sorts of codes. We finaly decied to pull the wire loom back off of the wires for the Fan Clutch and noticed that they were all fried. The first code was the fan clutch, so im thinking that must of been the cause. Needless to say I am having to buy a new harness, this has to fix the problem.
He started a thread, but I think he would have better luck here like you suggested. Hopefully he starts one in this "sub forum".
Here is his thread:
https://www.ford-trucks.com/forums/1...l#post20228629
Here is his thread:
Dp616
01-20-2019 01:09 AM
VictorwithaC
02-11-2017 08:52 PM
